Nokia N70 Keypad Replacement
crwdns2944105:0crwdne2944105:0
Orient the phone as shown.
Press the button with the plastic opening tool and slide the back case downward relative to the phone.
Remove the battery cover by lifting it away from the phone.
Insert the plastic opening tool into the marked space.
Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
Insert the plastic opening tool in the marked areas in between the front and back covers.
Pry each corner with the plastic opening tool until the front case completely detaches.
Remove the keypad by lifting it away from the phone.
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
