Nokia N70 Battery Replacement
Orient the phone as shown.
Press the button with the plastic opening tool and slide the back case downward relative to the phone.
Remove the battery cover by lifting it away from the phone.
Insert the plastic opening tool into the marked space.
Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
A recherche batterie et chargeur Nokia N 70,merci.
