Nokia G42 5G Charging Port Removal for Screen Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Nokia G42 5G Charging Port Removal for Screen Replacement, Disconnect the interconnect cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Disconnect the interconnect cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  2. Nokia G42 5G Charging Port Removal for Screen Replacement, Disconnect the antenna cables: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Disconnect the antenna cables: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Disconnect the antenna cables: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect both antenna cables by prying their connectors straight up from the sockets on the motherboard.
  3. Nokia G42 5G Charging Port Removal for Screen Replacement, Unseat the antenna cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Unseat the antenna cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Unseat the antenna cables: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to lift the antenna cables out of their recess in the frame.
    • During reassembly, connect the white antenna cable to the motherboard before connecting the black antenna cable. Then reseat the antenna cables into their recess.
  4. Nokia G42 5G Charging Port Removal for Screen Replacement, Pry up the charging port assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Pry up the charging port assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Pry up the charging port assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top edge of the charging port assembly is held in place with adhesive.
    • Insert the flat end of a spudger underneath the top right edge of the charging port assembly.
    • Pivot the charging port assembly up until you can grip it with your fingers.
  5. Nokia G42 5G Charging Port Removal for Screen Replacement, Remove the charging port assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia G42 5G Charging Port Removal for Screen Replacement, Remove the charging port assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the charging port assembly.
Manuel Haeussermann
crwdns2935283:007/13/22crwdne2935283:0
20,910 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,173crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 100
