Nokia G42 5G Back Cover Replacement
  1. Nokia G42 5G Back Cover Replacement, Eject the SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Eject the SIM card tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Eject the SIM card tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G42 5G Back Cover Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G42 5G Back Cover Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
    With the phone flat, screen up, insert the pick into the slot horizontally, then rotate the pick to the upright position, as shown in the photo in step 4.
    robincm - crwdns2934203:0crwdne2934203:0
    With the phone laying flat on its back, insert the pick into the slot horizontally, then flip the pick upright, as per photo in step 4.
    Don't try to fully remove the back cover just yet, as it's still connected with a cable.
    Jørn Gunnar Skorgevik - crwdns2934203:0crwdne2934203:0
  4. Nokia G42 5G Back Cover Replacement, Release the plastic clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Release the plastic clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Release the plastic clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G42 5G Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G42 5G Back Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
    Fingerprint-cable is easily broken. Careful around that button.
  7. Nokia G42 5G Back Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G42 5G Back Cover Replacement, Flip open the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Flip open the back cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Flip open the back cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
    Das ist nicht das Kabel für den Fingerabdrucksensor, sondern für den Ein-/Ausschalter und der Schalter hat sich bei mir gelöst und es hat mir einige Nerven gekostet das Maleur wieder zu beheben. Der Schalter ist nur sehr lose eingeclipst und muss dann zum Drehen und befestigen des Kabels am Motherboard mit dem Vorderteil gedreht werden.
    Holger La - crwdns2934203:0crwdne2934203:0
  9. Nokia G42 5G Back Cover Replacement, Unfasten the fingerprint reader bracket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader bracket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader bracket: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
    The metal fits under the black plastic near the screw shown to the left of the photo. When re-assembling, insert it back under here first, then lower the right-hand side back into place.
  11. Nokia G42 5G Back Cover Replacement, Disconnect the fingerprint reader: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Disconnect the fingerprint reader: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Disconnect the fingerprint reader: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G42 5G Back Cover Replacement, Release the fingerprint reader: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Release the fingerprint reader: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Release the fingerprint reader: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a pair of tweezers, grip the top of the fingerprint reader and lift it out and around the top plastic tab, separating it from the back cover.
  13. Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia G42 5G Back Cover Replacement, Remove the fingerprint reader: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to lift the fingerprint reader out of its bottom plastic tab.
    • Remove the fingerprint reader.
    • During reassembly, you'll need to transfer the fingerprint reader to the new back cover.
  14. Nokia G42 5G Back Cover Replacement, Only the back cover remains: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the back cover remains.
Manuel Haeussermann
crwdns2935283:007/13/22crwdne2935283:0
20.238 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:020.930crwdne2935297:0
Very simple and to the point! Worked like a charm. The only qualm I have is that the replacement did not have camera lens covers. They had little blue plastic circles over them but once you bring those up, there’s nothing underneath.
I ordered this to replace the back on my G310 5G and it does fit!
Jacqueline Taylor - crwdns2934203:0crwdne2934203:0
Comment on démonte les lentilles ?
hawai_ Léo - crwdns2934203:0crwdne2934203:0
Hey, how do I transfer lens cover???
Marko Shapochka - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 3,646
