Nokia 6350-1b Display Screen Replacement
  1. Nokia 6350-1b Display Screen Replacement, Display Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6350-1b Display Screen Replacement, Display Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move the plastic pry along the frame unlocking all of the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry too hard, doing so could crack the plastic frame.
  2. Nokia 6350-1b Display Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move along this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Display Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the flex cable from the logic board.
    • Disconnect the LCD display screen.
    • Remove the LCD display screen from the rest of the device.
  4. Nokia 6350-1b Display Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the new LCD display screen to the phone.
    • Reconnect the Logic Board to the flex cable.
  5. Nokia 6350-1b Display Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T-5 screwdriver, screw the four screws back into the phone.
  6. Nokia 6350-1b Display Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the cover back on the device so that it is in the correct position to be reinstalled.
    • Press gently on the cover so that it snaps back into place.
Anna
crwdns2935283:004/13/12crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
SUNY Cortland, Team 1-2, Getto Spring 2012 crwdns2935289:0SUNY Cortland, Team 1-2, Getto Spring 2012crwdne2935289:0
SUNYCORT-GETTO-S12S1G2
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,914
