In this guide, we show how to unscrew and remove the back case of the Nokia 2630b. This enables access to the motherboard, antenna, and LCD screen of the phone.
Press and the release button on both sides of the battery cover. While holding down the release buttons pull the battery cover away from the phone
Pull out the battery by holding the top of the battery and tilting out.
Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
NOTE: Keep the screws in a safe place while you continue working.
Remove screws using the same T5 screw bit to release the computer chip from the case
Carefully lift the black frame off the screen with your fingers
Carefully remove the computer chip and screen out of the black case with your fingers
The screen is attached to the motherboard by an orange ribbon
Carefully detach the ribbon from the motherboard using your fingers
Reattach new screen by connecting the orange ribbon to the computer chip
Place computer chip and screen back into black case
Carefully place keypad back in place
Snap the front case back in place with the bottom case with your fingers
Reassemble screws with microscrewdriver
Locate the four screws that secure the back case to the rest of the phone.
Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
