Nobis NB09 Battery Replacement
  1. Nobis NB09 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nobis NB09 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nobis NB09 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nobis NB09 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nobis NB09 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Jackson McAdams
crwdns2935283:004/01/15crwdne2935283:0
390 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Cichon Spring 2015 crwdns2935289:0UMass Dartmouth, Team 7-1, Cichon Spring 2015crwdne2935289:0
UMASSD-CICHON-S15S7G1
crwdns2942667:0crwdne2942667:0 3,080
