Use this replacement guide for step-by-step instruction on how to replace the power and accompanying buttons on the Wii U console's front face panel.
You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
Remove the five Phillips #0 screws.
Remove the four Tri-Wing Y1 screws.
Looks like one of the screws labelled as tri-wing here is actually a phillips.
Remove the CMOS battery door on the left side of the console.
Once the door is removed, remove the three Phillips #0 screws.
Gently pry off the top lid of the Wii U.
Rotate the device so that the front plate is facing you.
Remove the two Phillips #1 screws.
The one on the left was so tight it stripped extremely easily and won’t even budge when I have a good grip on it.
Remove the ribbon cable and separate the front plate from the main console.
Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
