Nintendo Wii Remote Front Cover Plate and Batteries Replacement
  1. Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - crwdns2934203:0crwdne2934203:0
  2. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Front Cover Plate and Batteries Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - crwdns2934203:0crwdne2934203:0
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - crwdns2934203:0crwdne2934203:0
crwdns2935229:043crwdne2935229:0
Emily
crwdns2935283:004/14/13crwdne2935283:0
1.869 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-44, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-44, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G44
crwdns2935297:028crwdne2935297:0
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
Graham Poor - crwdns2934203:0crwdne2934203:0
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
kivrin - crwdns2934203:0crwdne2934203:0
@kivrin Thanks for your comment. I’m pretty sure it should say tri-point, not tri-wing. I’ll update the instructions. Tri-wing screws have a more twisted/triangular form factor, like this.
Jeff Suovanen -
My controller (the original) had three tri-wing screws and one philips. Not sure why. Had to re-solder the negative battery terminal as it came off the bottom of the ‘top’ (faces bottom) of the board.
audvare - crwdns2934203:0crwdne2934203:0
why are you opening the controller for a battery replacement?
Dima silich - crwdns2934203:0crwdne2934203:0
The wording is unclear. It is the battery shell and front shell replacement guide. Not the actual batteries.
BTL Repair AU -
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 96
crwdns2936753:030crwdne2936753:0 357
crwdns2942667:0crwdne2942667:0 113,087
