Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly
  1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote and Wii Nunchuck: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote and Wii Nunchuck: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote and Wii Nunchuck: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery cover from the remote and batteries inside.
    • Unscrew the four visible Y1 tri-point screws on the remote.
  2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pry tool to gently pry apart the white tabs near the top of the controller.
    • Once you open up the remote, the two halves of the Wii remote should be separated.
    • There is a high chance that some of the plastic tabs may break off during the process, but the remote will still be able to be reassembled later without them.
  3. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pry tool or your fingers to remove the speaker piece from the remote.
    • Avoid puncturing the speaker! Although this won't outright break the speaker, the quality of the Wii remote's sound will become worse if punctured.
  4. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Simply remove the rest of the buttons and the conductive rubber pad button contacts.
    • Make sure to keep the buttons organized and close by, as they are very small and can easily be lost.
  5. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Go back to the side of the remote with the motherboard.
    • Gently lift and remove it from the base.
    • Be gentle while pulling out the motherboard, making sure not to rip the wires from the rumble motor.
  6. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the IR sensor screen.
  7. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the white tabs facing where the IR sensor screen was.
    • Place a tool under one tab and push up until both tabs pop out of place to remove the B trigger button.
  8. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a tool and place it under the rumble motor. Gently lift and remove it from the plastic housing.
    • Be careful while unseating the rumble motor so that the wires don't rip.
  9. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the plastic housing, you have to locate the two white tabs. Use your thumbs to gently pull them apart so that the plastic housing is removed from the motherboard.
    • Remove the rubber button from the plastic housing.
  10. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • All the pieces of the Wii remote are now disassembled.
    • Please check the photos on the left to make sure you have every single piece.
  11. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now the Wii remote will be reassembled.
    • Return the the buttons back to their original locations, and then place the corresponding rubber pad button contacts on top of the buttons.
  12. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the rubber pad button contact for the B trigger button on the plastic housing.
    • Align the two white tabs with the two indents on the sides and slide the plastic housing into place on the motherboard.
    • Seat the rumble motor back to its original location.
    • Make sure your are putting the white plastic housing on the correct side of the motherboard, as shown in Step 8.
  13. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Return the IR sensor screen to its location and slide it back into place.
    • Make sure the sensor screen is facing the correct direction.
  14. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the B trigger button back in its location and press the two white tabs into place so that it makes a click.
  15. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the motherboard on top of the back side of the remote and push down gently until the motherboard is flush with the top edge of the Wii remote.
    • Make sure the rumble motor is facing down while putting it back in place.
  16. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Face the bottom half of the Wii remote, with the motherboard side facing downwards, towards the top half of the Wii remote with the rubber pad button contacts facing upwards.
    • Align the sides and press together until all clips click into place.
    • Tighten all four Y1 tri-point screws.
  17. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Now Wii Nunchuk Disassembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Now Wii Nunchuk Disassembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two small Y1 tri-point screws that need to be loosened on the bottom of the remote.
  18. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • Once the screws are removed, you can remove the top half of the chassis off.
    • You may use an opening tool to assist with this step, such as the iFixit opening pick as an example.
    • Next gently pull off the thumb stick.
  19. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cable that plugs into the Wii remote needs to be removed from the whole nunchuk by pulling upwards on the strain relief boot.
    • The cable and circuit board assembly can still function when plugged into a Wii remote without the nunchuck's controller housing.
  20. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the wires over and remove the white conductive rubber pad button contact for the C and Z trigger buttons.
    • This will make it easier to slide the daughter board out from the white plastic housing cage for the C and Z trigger buttons in the next step.
  21. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then, remove the plastic housing cage that connects the C and Z button daughterboard to the Wii nunchuck's motherboard by unhooking the clips that hold onto the motherboard.
  22. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Wii nunchuck reassembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Wii nunchuck reassembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Wii nunchuck reassembly: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin reassembly by mounting the white plastic housing cage back onto the motherboard.
    • Slide the daughterboard for the C and Z buttons upwards into the plastic housing cage. Make sure not to force the daughterboard during this process to prevent breaking it.
    • Then slide the white conductive rubber pad button contact for the C and Z buttons on top of the daughterboard.
  23. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Seat the motherboard assembly, with the complete C and Z button housing cage, and Wii nunchuck cable back into the bottom half of the Wii nunchuck.
    • Seat the Wii nunchuck cable into the bottom half of the Wii remote.
    • Take care when putting the wires for the Wii nunchuck cable back in the Wii remote's bottom half of the remote casing, because they can easily fall out if not seated correctly.
  24. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then press the analog stick onto the Wii nunchuck's analog stick stem to reattach it.
  25. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lastly push the top half of the Wii nunchuck back on top of the bottom half of the remote. Screw the two Y1 tri-wing screws on the bottom half of the remote to complete the reassembly.
crwdns2935229:024crwdne2935229:0
Linda Bowers
crwdns2935283:010/24/16crwdne2935283:0
886 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Great guide! I took one of my remotes apart some years ago. Now, with fresh tri-wing driver in hand, I am ready to reassemble the thing. Problem: where to solder the green ground? It currently is fused to the nunchuk connector housing, but where does the other end go??? Wish I'd noted that, back then
K. Lehnert - crwdns2934203:0crwdne2934203:0
Very accurate guide! I was able to clear debris between the buttons with ease.
Aiden - crwdns2934203:0crwdne2934203:0
Hello do you have tutorials for unassembly nunchuck's connector please?
Patrick WAI KHAI SONE - crwdns2934203:0crwdne2934203:0
You have to unsolder the cable if you want to replace it. See this replacement cable for the Wii nunchucks, where the description says at the bottom:
Tai Lam -
Thank you ! My A button registered the click half the time : turns out it had corrosion, now it works like a charm !
CreaZyp! - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 91
crwdns2936753:030crwdne2936753:0 353
crwdns2942667:0crwdne2942667:0 47,153
