Nintendo Switch Pro Controller Battery Replacement
  1. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    Be carefull, these screws are super easy to strip even with the right tools.
    Lukas Eberharter - crwdns2934203:0crwdne2934203:0
    I tried editing these instructions after I had trouble with stripping screws, but it doesn't seem to take. The issue is that these are JIS and not Phillips screws. They are VERY similar looking but a Phillips head screwdriver will strip the screws.
    Isaac Webb - crwdns2934203:0crwdne2934203:0
    I tried using a Philips #00 screwdriver but it didn’t work
    vincent ingrassia - crwdns2934203:0crwdne2934203:0
    Don't even think about trying Phillips. There are some other guides online that say you'll be fine, but they're wrong. Even one attempt with Phillips WILL strip these, and you will never, ever get this controller open once that happens. Even with JIS they're really hard to get out and really easy to strip.
    Luke T. Allen - crwdns2934203:0crwdne2934203:0
  2. Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Battery Replacement, Remove the clear plastic cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:040crwdne2935229:0
Daniel Tagalog
crwdns2935283:010/10/19crwdne2935283:0
1.828 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G2, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S11-G2, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S11G2
crwdns2935297:044crwdne2935297:0
crwdns2947412:012crwdne2947412:0
now what after taking the battery out
Seani M - crwdns2934203:0crwdne2934203:0
Install the replacement battery and follow the steps in reverse order…
frzno72 -
easy peasy only have to recycle battery
Dan Carroll - crwdns2934203:0crwdne2934203:0
Where can I buy genuine ctr-003 batteries in germany/europe?
smol_tsukiko - crwdns2934203:0crwdne2934203:0
You can buy them directly in the iFixit Europe or in your case in the Germany store.
Henrynaja -
My controller would not turn on one day. Followed this guide to remove the battery and just reseat it . Works now! Thank you!
Unthar - crwdns2934203:0crwdne2934203:0
Used the iFixit PH00 and it stripped my screws
gpetit - crwdns2934203:0crwdne2934203:0
Guide facile à suivre et rapide à exécuter. Merci!
Philippe Côté - crwdns2934203:0crwdne2934203:0
Thanks for sharing this "how to" guide. Upon replacing my battery I realize that there was a malfunctioning into the USB-C port which was not charging batteries through the controller port. I'm writing this in order to alert some people that the problem with batteries been depleted can be related to charging issues. Check it before replacing batteries! =)
Danilo Mazzolani - crwdns2934203:0crwdne2934203:0
質問ですが、バッテリーを抜いた状態でusbで繋いだら動きますか?
兼城賢蔵 - crwdns2934203:0crwdne2934203:0
動く。有線無線どちらも。
Ahellina -
The battery says to charge it to 100% + 2 hours and then use the controller so that it uses up the entire battery and then charge to 100% again. If you're not playing Nintendo for hours, how do you use up the battery in the controller?
robbieleffel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 133
crwdns2936753:07crwdne2936753:0 632
crwdns2936753:030crwdne2936753:0 1,753
crwdns2942667:0crwdne2942667:0 79,357
