Nintendo Switch Lite LCD Replacement
  1. Nintendo Switch Lite LCD Replacement, Remove the back panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite LCD Replacement, Remove the top and bottom back panel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the top and bottom back panel screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite LCD Replacement, Release the clips securing the back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Release the clips securing the back panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite LCD Replacement, Continue releasing the clips around the device: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Continue releasing the clips around the device: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite LCD Replacement, Twist to release the clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Twist to release the clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite LCD Replacement, Slide and pry around the corners: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Slide and pry around the corners: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite LCD Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite LCD Replacement, Remove the shield plate: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite LCD Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite LCD Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Nintendo Switch Lite LCD Replacement, Remove the heat sink: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  15. Nintendo Switch Lite LCD Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  16. Nintendo Switch Lite LCD Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  17. Nintendo Switch Lite LCD Replacement, Remove the game card reader and headphone jack: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the game card reader and headphone jack: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
  18. Nintendo Switch Lite LCD Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
  19. Nintendo Switch Lite LCD Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
  20. Nintendo Switch Lite LCD Replacement, Remove the right trigger button assembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
  21. Nintendo Switch Lite LCD Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right trigger button assembly.
  22. Nintendo Switch Lite LCD Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  23. Nintendo Switch Lite LCD Replacement, Disconnect the antenna cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the antenna cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the antenna cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  24. Nintendo Switch Lite LCD Replacement, Disconnect the fan cable: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  25. Nintendo Switch Lite LCD Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  26. Nintendo Switch Lite LCD Replacement, Disconnect the screen cable: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the screen cable: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
  27. Nintendo Switch Lite LCD Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  28. Nintendo Switch Lite LCD Replacement, Disconnect the digitizer cable: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the digitizer cable: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  29. Nintendo Switch Lite LCD Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  30. Nintendo Switch Lite LCD Replacement, Disconnect the right joystick cable: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the right joystick cable: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  31. Nintendo Switch Lite LCD Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  32. Nintendo Switch Lite LCD Replacement, Remove the motherboard assembly: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
  33. Nintendo Switch Lite LCD Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  34. Nintendo Switch Lite LCD Replacement, Remove the right joystick: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
  35. Nintendo Switch Lite LCD Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
  36. Nintendo Switch Lite LCD Replacement, Remove the left speaker module: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the left speaker module: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
  37. Nintendo Switch Lite LCD Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the 4.5 mm screw securing the left speaker module.
  38. Nintendo Switch Lite LCD Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the speaker module up and out of its recess to remove it.
    • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
  39. Nintendo Switch Lite LCD Replacement, Disconnect the motherboard interconnect cable: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the motherboard interconnect cable: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  40. Nintendo Switch Lite LCD Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
  41. Nintendo Switch Lite LCD Replacement, Disconnect the screen and volume button cables: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the screen and volume button cables: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
  42. Nintendo Switch Lite LCD Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
    • Repeat this procedure for the volume buttons cable.
  43. Nintendo Switch Lite LCD Replacement, Remove the volume buttons: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the volume buttons: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the volume buttons.
  44. Nintendo Switch Lite LCD Replacement, Disconnect the joystick cable: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Disconnect the joystick cable: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
  45. Nintendo Switch Lite LCD Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
  46. Nintendo Switch Lite LCD Replacement, Remove the left trigger button assembly: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the left trigger button assembly.
  47. Nintendo Switch Lite LCD Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left trigger button assembly.
  48. Nintendo Switch Lite LCD Replacement, Remove the daughterboard: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two 4.5 mm screws
    • Two 6 mm screws
  49. Nintendo Switch Lite LCD Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the daughterboard up and out of its recess to remove it.
  50. Nintendo Switch Lite LCD Replacement, Remove the left joystick: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the left joystick.
  51. Nintendo Switch Lite LCD Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lift the joystick up and out of its recess.
  52. Nintendo Switch Lite LCD Replacement, Remove the midframe assembly: crwdns2935265:052crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Three 2.5 mm screws
    • One 6 mm screw
  53. Nintendo Switch Lite LCD Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to lift the midframe assembly up and out of its recess.
    • Remove the midframe assembly.
  54. Nintendo Switch Lite LCD Replacement, Remove the buttons: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement, Remove the buttons: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point in the repair, remove all of the buttons if you haven't done so already, to prevent them from falling out and getting lost.
    • Use these two photos for reference.
  55. Nintendo Switch Lite LCD Replacement, Remove the LCD: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the back side of the LCD along the top edge for 2 minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the LCD if you plan on reusing it, as it's susceptible to heat damage.
  56. Nintendo Switch Lite LCD Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the frame and the top edge of the LCD to begin separating the two components.
    • Make sure to insert the pick completely under the LCD panel so you don't split and damage it.
    • You'll know you're splitting the panel if the silver backing bubbles and separates from the white lining.
  57. Nintendo Switch Lite LCD Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the top edge of the LCD to slice the adhesive.
  58. Nintendo Switch Lite LCD Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back side of the LCD along the right edge for 2 minutes.
  59. Nintendo Switch Lite LCD Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the opening pick around the right edge of the LCD, slicing the adhesive.
    • The LCD and digitizer cables are placed in a way to prevent them from easily snagging on the opening pick, but still use caution when sliding the opening pick along the gap.
  60. Nintendo Switch Lite LCD Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back side of the LCD along the bottom edge for 2 minutes.
  61. Nintendo Switch Lite LCD Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the opening pick along the bottom edge of the LCD to slice the adhesive.
    • You'll need to remove and reinsert the opening pick at various points along the LCD's edge to work around the frame.
  62. Nintendo Switch Lite LCD Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back side of the LCD along the left edge for 2 minutes.
  63. Nintendo Switch Lite LCD Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sliding the opening pick along the left edge of the LCD to slice the adhesive.
    • Take care not to snag the LCD's daughterboard cable on the opening pick.
  64. Nintendo Switch Lite LCD Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:064crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:064crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or your fingers to lift the LCD up and out of the frame to remove it.
    • If you're reusing the LCD (or your new LCD does not come with pre‑installed adhesive), follow this guide to install pre-cut adhesive around the perimeter before reassembly.
  65. Nintendo Switch Lite LCD Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite LCD Replacement: crwdns2935265:065crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • If you're also replacing the digitizer, you can skip this step.
    • Use the flat end of a spudger to scrape off the remaining adhesive around the perimeter of the digitizer.
    • Prior to installing a new LCD, use isopropyl alcohol and a microfiber cloth to clean and remove any residual adhesive from the back side of the digitizer. Wait several minutes for any remaining alcohol to evaporate before installing the LCD.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
crwdns2935229:055crwdne2935229:0
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
41.240 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
crwdns2947412:021crwdne2947412:0
Followed the guide to replaced a cracked screen on a Switch Lite, all good, guide was easy to follow and refitting wasn't too hard either, just a reversal of the disassembly
Luke Randall - crwdns2934203:0crwdne2934203:0
Fantastic guide, exactly what I was looking for! Unfortunately I managed to make the tape unusable and I need tape to connect the lcd to the digitizer and the digitizer to the case. I will likely use 2-3mm tape for the lcd to digitizer but I'm unsure what to use to connect the digitizer to the case. Any suggestions?
Sam Red - crwdns2934203:0crwdne2934203:0
Thanks for taking the time to type this up. Really appreciate the effort that went in to this guide.
Matthew D. H. - crwdns2934203:0crwdne2934203:0
Great guide, I wish it would mention some of the procedures to tape the screen back in. After that, reversing the process was easy.
Stephen Hotchkiss - crwdns2934203:0crwdne2934203:0
For gluing the screen and digitizer back in, I would strongly recommend liquid glue, like Zhanlida T-8000 for example. You can apply it very precisely and you can also correct/remove it if needed pretty easily. I used this stuff to repair around 200 phones and tablets in the last couple of years and were never disappointed.
Also I would remove the digitizer AND the screen together, before removing the screen first from the digitizer… This will make the process of removing the screen from the digitizer a lot easier and safer.
I have ordered a crystal replacement case and a used lite with a scratched digitizer.. Have glued in the replacement digitizer so far, the console should arrive tomorrow.
Gluing in the digitizer was a breeze, just applied some glue all around (be careful not to use too much) and then just pressed down the digitizer all around and put a book on the top… Let the glue harden for around 24 hours and you are good to go.
Will leave some feedback how the screen removal went tomorrow. ;)
mathiasludewig - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 113
crwdns2936753:07crwdne2936753:0 683
crwdns2936753:030crwdne2936753:0 3,230
crwdns2942667:0crwdne2942667:0 188,689
