Nintendo Switch Lite Heat Sink Replacement
    1. Nintendo Switch Lite Heat Sink Replacement, Remove the back panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Magnetic Project Mat
      $19.95
      • Before beginning this repair, make sure that the device is completely turned off.
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    2. Nintendo Switch Lite Heat Sink Replacement, Remove the top and bottom back panel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Remove the top and bottom back panel screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the following screws securing the back panel:
      • Two 3.6 mm-long screws on the top of the device
      • Two 3.6 mm-long screws on the bottom of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    3. Nintendo Switch Lite Heat Sink Replacement, Release the clips securing the back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Release the clips securing the back panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening tool into the left speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips securing the back panel.
      • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
    4. Nintendo Switch Lite Heat Sink Replacement, Continue releasing the clips around the device: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Continue releasing the clips around the device: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    5. Nintendo Switch Lite Heat Sink Replacement, Twist to release the clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Twist to release the clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening tool into the right speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips.
    6. Nintendo Switch Lite Heat Sink Replacement, Slide and pry around the corners: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Slide and pry around the corners: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    7. Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    8. Nintendo Switch Lite Heat Sink Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the bottom edge of the back panel, opening it like a book.
      • Remove the back panel.
    1. Nintendo Switch Lite Heat Sink Replacement, Remove the shield plate: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the four screws securing the shield plate:
      • Three 3.1 mm screws
      • One 4.5 mm screw
    2. Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger or your fingers to lift the shield plate up and out of the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal putty.
      • Remove the shield plate.
      • Clean off the old thermal putty from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal putty to the heat sink before reassembly.
    1. Nintendo Switch Lite Heat Sink Replacement, Disconnect the interconnect cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Disconnect the interconnect cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    2. Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Do Not Use Metal Tweezers! Metallic tweezers can short-circuit the ribbon cable/connector and damage your device.
      • Use a spudger or a pair of non-conductive (nylon or ceramic) tweezers to slide the interconnect cable out of its connector on the motherboard.
    3. Nintendo Switch Lite Heat Sink Replacement, Disconnect the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement, Disconnect the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
      • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
    1. Nintendo Switch Lite Heat Sink Replacement, Remove the heat sink: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
      • The foam only needs to be peeled back enough to clear the fan.
    2. Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    3. Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Heat Sink Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
43,097 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
What kind of thermal paste should I use and should it be conductive or non conductive?
Fern - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 74
crwdns2936753:030crwdne2936753:0 283
crwdns2942667:0crwdne2942667:0 17,182
