crwdns2959928:0crwdne2959928:0 ↓Follow this guide to replace a broken or faulty fan in the Nintendo Switch game console.
The Nintendo Switch uses JIS screws, which are slightly different than Phillips. We don’t recommend using Phillips drivers for JIS screws; however, iFixit Phillips bits are specifically designed to be compatible with JIS screws. If you use a non-iFixit Phillips driver, you risk stripping the screws.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Normal thermal paste isn't designed to bridge large gaps, so you'll need thermal putty or viscous thermal paste.
Note: This guide is compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively), but the replacement fans are model and year specific.
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
Spudger4.9
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
Use a JIS 00 driver to remove the following screws securing the rear panel:
One 2.5 mm-long screw on the top edge of the device
Two 2.5 mm-long screws on the bottom edge of the device
Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
Use your finger to flip up the kickstand on the back of the device.
If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
Close the kickstand.
Open the game card cartridge flap.
Lift the rear panel straight up from the bottom of the device and remove it.
Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
Peel the foam block off the MicroSD card reader.
Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
Set the foam block onto the connector and press it into place.
Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
crwdns2935267:0crwdne2935267:0iFixit Thermal Putty$9.95
Insert a spudger underneath the shield plate along the edge of the device.
Pry up to lift the shield plate and remove it from the device.
During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
Insert the point of a spudger beneath the battery cable and slowly lift straight up to disconnect the flat‑topped battery connector from the board.
Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
crwdns2935267:0crwdne2935267:0iFixit Adhesive Remover$19.99
Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
Press the top of the foam with your finger to hold it in place.
Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
Use a pair of tweezers or your fingers to remove the headphone jack bracket.
Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
Use a JIS 00 driver to remove the three 4.8 mm screws securing the fan.
Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
crwdns2935229:0265crwdne2935229:0
crwdns2947412:058crwdne2947412:0
If your joycons are not charging, it could be the fans fault as they seem to share a 1.8v and or 5v rail, I had both joycons refusing to charge, and the fan was not working, so by replacing the fan, it had them charging properly again.
Corbin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
oh? i was wondering why my joycons died and never turned on. i though the hot switch short circuited them. the same thing happened to mine. The fan died as well as my joycons. very useful mate. thanks for the info!
Robby Ninte - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I changed the fan and it still don’t charge my Joycon. What should I do?
baron154 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’ve recently found a video that shows what can be wrong with Switch with the same issue, but working fan https://www.youtube.com/watch?v=WuQC3ipu... . In the comments people confirmed several times that it helps.
Andrey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If I'm just replacing the fan, do I need to clean off/reapply any thermal paste?
Postponderance - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
