crwdns2959928:0crwdne2959928:0 ↓Follow this guide to replace a damaged or faulty digitizer on the Nintendo Switch game console.
The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.
Note: If the screen stopped working, you may just need to replace the LCD panel, rather than the digitizer.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Normal thermal paste isn't designed to bridge large gaps, so you'll need thermal putty or viscous thermal paste. You will, however, need regular replacement thermal paste for the CPU.
You can complete this repair without removing the heat sink and the game card reader, but it makes disconnecting and reconnecting the LCD panel ribbon cable much more difficult. Keep this in mind when you perform this repair.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
Use a JIS 00 driver to remove the following screws securing the rear panel:
One 2.5 mm-long screw on the top edge of the device
Two 2.5 mm-long screws on the bottom edge of the device
Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
Use your finger to flip up the kickstand on the back of the device.
If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
Close the kickstand.
Open the game card cartridge flap.
Lift the rear panel straight up from the bottom of the device and remove it.
Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
Peel the foam block off the MicroSD card reader.
Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
Set the foam block onto the connector and press it into place.
Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
crwdns2935267:0crwdne2935267:0iFixit Thermal Putty$9.95
Insert a spudger underneath the shield plate along the edge of the device.
Pry up to lift the shield plate and remove it from the device.
During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
Insert the point of a spudger beneath the battery cable and slowly lift straight up to disconnect the flat‑topped battery connector from the board.
Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
crwdns2935267:0crwdne2935267:0iFixit Adhesive Remover$19.99
Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
Press the top of the foam with your finger to hold it in place.
Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
Use a pair of tweezers or your fingers to remove the headphone jack bracket.
Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
Apply a suction cup to the bottom-left corner of the screen.
Pull up on the suction up with strong, steady force to create a gap.
Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
Slide the opening pick along the bottom edge of the screen to slice the adhesive.
Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
Insert a second opening pick into the gap to the left of the first pick.
Slide the opening pick back towards the left side of the device.
Leave the opening pick inserted.
Heat the left edge of the screen for around two minutes to help soften the adhesive.
Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
Heat the top edge of the screen for around two minutes to help soften the adhesive.
Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
Heat the right edge of the screen for around two minutes to help soften the adhesive.
Place the flat end of a spudger into the gap along the left edge of the screen.
Carefully and slowly lift the left edge of the screen, opening it like a book.
Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
Heat the top edge of the screen assembly for around two minutes to help soften the adhesive holding the LCD panel to the digitizer.
Turn the screen assembly over.
Insert an opening pick in between the LCD panel and the digitizer at the top-left corner.
Slide the opening pick along the top edge of the screen assembly to slice the adhesive.
Heat the left edge of the screen assembly for around two minutes to help soften the adhesive.
Insert and slide the opening pick along the left edge of the screen assembly to slice the adhesive.
Continue sliding the opening pick around the bottom-left corner of the screen assembly to slice the adhesive.
Heat the bottom edge of the screen assembly for around two minutes to help soften the adhesive.
Continue sliding the opening pick along the bottom edge to slice the adhesive.
Heat the right edge of the screen assembly for around two minutes to help soften the adhesive.
Insert the flat end of a spudger in between the LCD panel and the digitizer along the left edge of the screen assembly.
Carefully and slowly lift up the left side of the LCD panel, opening it like a book.
Continue lifting the LCD panel away from the digitizer to separate the two components.
Only the digitizer panel remains.
If your new digitizer does not come with pre-installed adhesive, follow this guide to install pre-cut adhesive around the perimeter before reassembly.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your new digitizer doesn’t work properly after you boot up the device, turn it back off and disconnect and reconnect the battery connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
crwdns2935229:036crwdne2935229:0
crwdns2947412:017crwdne2947412:0
Are Digitizers from original models (HAC-001) and revision models (HAC-001-(01)) compatible?
I don’t mean switch lite but the revision with the longer lasting battery.
GBG HNM - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes, the digitizer is compatible with both models!
Craig Lloyd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The ribbon cable for the digitizer is too short and cannot plug in to the connecter on the game card reader. Any ideas what the issue could be? im using a custom housing for it
Daniel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
there should be a slit on the front housing where the ribbon cable goes straight through to the back. pay attention at where it comes out of on step 39
Ricardo Ortega - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
