Remove the four sticky pads from the bottom of the device.
Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
Use your hands to pull the back panel away from the controller.
Remove the four 12 mm screws from the small square panel on the right with a Phillips #0 screwdriver.
Using your hands, unscrew the ball on top of the joystick.
Pull the joystick through the back of the NES Advantage Gamepad.
crwdns2935219:0crwdne2935219:0
