Nintendo Game Boy Advance SP Shell Replacement
  1. Nintendo Game Boy Advance SP  Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the screw on the battery compartment with a Phillips #00 screwdriver.
    • Open the battery compartment and remove the battery.
    • Remove the four 6.45 mm Tri-point Y00 screws from the corners of the device.
    • Remove the two 4.6 mm Tri-point Y00 screws from inside the battery compartment and game cartridge comparments.
  2. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift off the bottom cover to expose the motherboard.
    • If you need to, use isopropyl alcohol to clean the power and volume sliders.
    • Remove the three 4mm Phillips #00 screws from the motherboard.
    • Gently lift up the motherboard and remove the ribbon cable by gently pulling the two clips on the side up and towards the cable.
    • Remove the small Phillips #00 screw hidden underneath the ribbon cable. It holds the hinge cover of the top screen together.
  3. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the GBA SP screen and use the pointed end of a spudger to remove the rubber pads around the screen bezel.
    • Remove the five Tri-point Y00 screws hidden beneath the rubber pads.
    • Remove the bezel from the screen with a spudger.
    • Be careful not to pull on the ribbon cable as the bezel comes off.
    are all 5 screws the same size?
    scott lindquist - crwdns2934203:0crwdne2934203:0
    Late to the party, but I can confirm that all 5 screws described in this step are the same size.
    When I worked on this step to remove the shell on my Game Boy Advance SP, I noticed the 5 screws were Phillips #00 instead of Tri-point Y00. I believe my SP is a model for Southeast Asia or Australia, so perhaps there are some regional differences? YMMV.
    mattconsumes - crwdns2934203:0crwdne2934203:0
  4. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hinges from the original shell. This is the most difficult step, as it requires a lot of force to remove the hinges.
    • Apply pressure with the pointed end of a spudger from the inside, pushing out with plenty of force. The hinges will likely fly out of the shell a few feet; this is normal.
    • Once the hinges are removed, remove the caps on the end of each hinge.
    • Be careful with the spudger. Pushing out the hinges requires a massive amount of force, and you might injure your hand on accident if you do not take extra caution.
    Extremely careful here with the position of your hands as you’re pushing the hinges out. I managed to severely injure myself from the sudden jolt scraping my fingers on the case when the hinges gave in. Preferrably, position your hand and screwdriver around 30 degrees from the horizontal of the case to avoid this and press the case firmly against a table.
    Hector Carrera - crwdns2934203:0crwdne2934203:0
    the easier way to do this is to stand the case on it’s side on the edge of something, I just used my desk mat at the edge of my desk, place your spudger on the inner metal part and tap with a small hammer or something, I used a pair of pliers. Way less likely to hurt your hand because you don’t have to grip the case as hard or push as hard. Work smarter
    Kira - crwdns2934203:0crwdne2934203:0
    Interestingly enough, I found that, if you don't plan to use the old shell for anything else, it may be easier in some cases to cut the plastic around the hinges, which I did with a model kit cutting tool (the old shell was very brittle and broke apart into pieces too small for me to push the hinges out of). Eye protection is recommended.
    Nicholas - crwdns2934203:0crwdne2934203:0
    There is a much simpler way to remove these hinges. By:
    - Close the lid of your SP
    - Pushing the hinge out slightly with your spunger so it slightly protrudes
    - Open the lid and then finish pushing the hinge out the rest of the way
    Doing this you SHOULD NOT have to use much force at all and the hinges will pop out pretty easily. Also this ensures that the hinges are in the correct position when re-installed in reverse
    Referenced from https://www.youtube.com/watch?v=gN3nsTFl...
    WienerDog - crwdns2934203:0crwdne2934203:0
  5. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out your replacement shell.
    • Push the hinges from the old case into the slot of the new case about halfway while the case is closed.
    • Then open the shell and push the hinges the rest of the way in.
    The hinges will need to be slotted into your new end caps before being pushed in
    Peter DeVita - crwdns2934203:0crwdne2934203:0
  6. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your screen into the new shell and affix the bezel into position; the ribbon cable should slide through the gap like before.
    • The case should click into place so that it stays together even without screws. There also may be a small gap between the top and bottom case, as this common on third party cases.
    • Reinstall the five Tri-point Y00 screws around the screen.
    • Reinstall the speaker, buttons, and silicone pads into the bottom case.
    I found it easier to reattach the screen ribbon cable before adding the buttons and speaker. Additionally, you’ll want to reattach the small half hinge part before the buttons too.
  7. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the ribbon cable into the motherboard and lock it into place.
    • Guide the motherboard into the new case and screw it down with the three 4mm Phillips #00 screws.
    • Install the square, threaded washer on the back of the shell. This is where the battery compartment's screw gets held, so it is important!
    There’s no mention of reinstalling the top hinge cover with that hidden little screw! It was important to do this before screwing the motherboard back down.
    Justin Gagnon - crwdns2934203:0crwdne2934203:0
    That’s exactly what I was going to comment. I had to go back and undo it all once I realised that I had left out the hinge cover. I might also suggest hooking in the ribbon before you put in the buttons. Mine fell out anyway. Also… make sure you put the speaker in the correct way. Trust me.
    Jiu Kyung - crwdns2934203:0crwdne2934203:0
  8. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the volume and power sliders are in place before putting the back cover on.
    • Put the back cover on and push the two parts together.
    • Screw the shell together with the four 6.45 mm Tri-point Y00 and two 4.6 mm Tri-point Y00 screws, then reinstall the battery.
  9. Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP  Shell Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinstall the rubber pads around the screen bezel—they stop the shell from rubbing together on the inside.
    • Find the "Nintendo" logo replacement sticker and put it into place.
    • Test the console and make sure it works properly!
    Removing the hinge doesn’t have to be as much of a struggle if you orient the screen correctly to remove it. The remove lock the screen into the open position, then push the hinge out. To push the hinge back in , push it in halfway while the screen is closed , then open the what would be the locked open position and the hinge should be able to more easily slide into final position.
    Wesley - crwdns2934203:0crwdne2934203:0
Rehousing your GBA SP can be a fun project! It doesn’t take very long, and once you’re done you’ll have a fun new customized console! The ease of difficulty and ability to express yourself both make this project well worth attempting.
crwdns2935229:022crwdne2935229:0
Rocko Bishop
crwdns2935283:009/30/20crwdne2935283:0
680 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G1, Raign Fall 2020 crwdns2935289:0University of North Texas, Team S1-G1, Raign Fall 2020crwdne2935289:0
UNT-RAIGN-F20S1G1
Excellent guide thank you! My GBA is looking great now :)
Hello this guide is great but it has some flaws (missing some steps) but I used an eXtremeRate GBA SP shell and they are the best ones to go with because they have It molded in a way to remove the Nintendo logo sticker and so you can put in a ips screen with out needing to trim and it is made out of a high quality plastic and it better than other third party shell and I used purple/blue color
dead - crwdns2934203:0crwdne2934203:0
Thanks for the helpful guide! A couple things of note that I noticed along the way:
If you're replacing the screen lens, make sure you line it up properly so the end result isn't crooked.
Make sure to organize your screws, a mismatched screw can poke a hole through the shell.
Be gentle but firm when tightening a screw. I definitely messed up a screw or two being too forceful.
(I might be stupid) keep an eye on the battery lid screw hole. Mine ended up warping so I had to duct tape the lid to the shell.
If you're doing a button replacement too, be careful with the triggers.
Noah - crwdns2934203:0crwdne2934203:0
Excelent guide, just a quick detail: you forgot to add the part when you put the screw under the screen ribbon, the one that afix the hinge in place. The rest was amazing, thank you very much.
Daniel - crwdns2934203:0crwdne2934203:0
Bad guide, misses crucial parts (especially proper installation of the shoulder buttons)
edit: and it misses the top hinge cover.
Zac - crwdns2934203:0crwdne2934203:0
Sad that there is no step to remove the screen if you replace the shell
Blaxyy - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 213
crwdns2936753:030crwdne2936753:0 942
crwdns2942667:0crwdne2942667:0 61,927
