Nintendo DS Lite Battery Replacement
  1. Nintendo DS Lite Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DS Lite Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
    Ritchie - crwdns2934203:0crwdne2934203:0
    I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
    whittlegirls - crwdns2934203:0crwdne2934203:0
    bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
    Marie-Julie Richer - crwdns2934203:0crwdne2934203:0
    Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
    Polaris -
  2. Nintendo DS Lite Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
crwdns2935229:047crwdne2935229:0
Matthew Newsom
crwdns2935283:001/05/10crwdne2935283:0
40 905 crwdns2915208:0crwdne2915208:0
crwdns2935297:067crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - crwdns2934203:0crwdne2934203:0
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - crwdns2934203:0crwdne2934203:0
Thanks but will a dsi battery work
Zach - crwdns2934203:0crwdne2934203:0
My battery cover won’t come off.
Jake - crwdns2934203:0crwdne2934203:0
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
crwdns2936751:024crwdne2936751:0 33
crwdns2936753:07crwdne2936753:0 208
crwdns2936753:030crwdne2936753:0 908
crwdns2942667:0crwdne2942667:0 62,687
