How to replace the power cable on an N64 power supply.
Unscrew the 2 security screws on the corners of the case using a 4.5mm security bit driver.
Remove the cover by gently prying from the side with the screws.
Remove the circuit board from the other half of the plastic case by pulling it straight out
Remove the original power leads by melting the solder using a soldering gun.
Clear the boot by pulling the copper wires out with pliers.
Use the drill to drill out the wire sheathing.
Drill each hole twice.
First, use a 5/64th drill bit. Then, use a larger 1/8th drill bit to finish.
Feed the new cable through the boot .
Glue it in place by applying glue to the wire (close to the desired location of the boot) and sliding the boot into place.
Align the wires with their original positions on the circuit board.
Looking at the component side of the board, the hot side is marked with an L for load and the neutral is marked with an N.
The neutral wire goes here, the hole closer to the center of the circuit board.
The hot wire goes here, closer to the outside.
Hola una preuguta me podrian proporcionar los datos del varistor V1
Seme quemo y no seven los datos porfavor
Solder the new wires onto the circuit board.
Use a flexible glue to put on the original adhesive.
Insert the board, aligning the boot with the slot.
To reassemble your device, follow steps 1-3 in reverse order.
Stap 5 and Stap 6 can be replaced using boiled water and soak de boot for a few minutes. Now you can pull out the old wires from the boot.
