Nintendo 3DS Cartridge Reader Replacement
  1. Nintendo 3DS Cartridge Reader Replacement, Opening the Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #00 screwdriver to loosen the four screws along the top of the back cover.
    • These screws are captive and should remain in the cover after loosing them.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
  2. Nintendo 3DS Cartridge Reader Replacement, Opening the Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS Cartridge Reader Replacement, Opening the Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS #00 screwdriver to remove all 10 screws to access the third layer and the motherboard of the 3DS.
    • Don't forget the one near the game card slot, it is silver, not black.
    • Exercise caution when opening the device. There are delicate ribbon cables at the top of the device that you risk ripping, so open slowly and gently.
    • Make sure to keep the screws, as you will need them for reassembly. Don't lose them!
  3. Nintendo 3DS Cartridge Reader Replacement, Removing the Cartridge Reader: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS Cartridge Reader Replacement, Removing the Cartridge Reader: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS Cartridge Reader Replacement, Removing the Cartridge Reader: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the cartridge reader look for 4 solder joints, 2 on each side of the reader (see image).
    • Apply heat to them with a soldering iron to melt the solder and take out the reader.
    • Use a spudger to lift the reader out of the board as you apply heat.
    • You can apply some solder flux or even some new solder wire to form an alloy between the old and new metals, this would ease the task.
    • The soldering iron can cause severe burns if not used properly. Proceed with caution and have an adult in the room with you if underage.
  4. Nintendo 3DS Cartridge Reader Replacement, Solder the New Cartridge Reader: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the new reader with the solder points
    • Use a soldering iron to connect it to the motherboard.
    • Be careful when soldering and work in a well-ventilated area.
  5. Nintendo 3DS Cartridge Reader Replacement, Cleaning up: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before reassembling the device use isopropyl alcohol and a cotton swab and clean the surrounding area, removing all of the remaining flux residue.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abraham Zapata
crwdns2935283:003/05/24crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 8-10, Grodsky Spring 2024 crwdns2935289:0CSU Los Angeles, Team 8-10, Grodsky Spring 2024crwdne2935289:0
CSULA-GRODSKY-S24S8G10
It might help to utilize a prerequisite guide up until the actual replacement of the cartridge slot. The IR board replacement is short and similar in step number in this regard.
Russ9876 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 214
crwdns2942667:0crwdne2942667:0 3,489
