This guide illustrates how to remove the upper rear panel from the Nintendo 2DS to access the battery and other parts of the device.
Remove the two Phillips captive screws securing the upper rear panel.
Hinge the upper rear panel upwards and outwards to remove it.
Remove the battery from its housing by lifting it up from the side closest to the outside edge.
crwdns2935229:040crwdne2935229:0
crwdns2947412:05crwdne2947412:0
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
This didnt help my problem
maybe its because you did not plug the battery correctly matthew
or maybe its just not working ludovic 🫡
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
