Ninja Professional Blender BL660 Circuit Board Replacement
crwdns2942287:0crwdne2942287:0If the blender doesn't power on, the circuit board may be damaged. This guide will show you how to replace a non-responsive circuit board.
crwdns2944105:0crwdne2944105:0
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
Pull the power cord through the mid-section opening.
Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
Slide the cover all the way to the end of the power cord.
Using the Phillips #2 screwdriver remove the 4 screws (10mm long, 5mm wide) on the circuit board.
To give the circuit board further range of motion, remove the pictured zip ties holding the cables.
Desolder the seven wires indicated from the circuit board.
For further instruction on sodering and desodering reference iFixit's guide.
Once the wires are cool to the touch, remove circuit board.
Where to purchase circuit board?
TTA1 number please
Donde puedo comprar una placa de circuito nueva para licuadora NINJA BL610
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:08crwdne2947412:0
Thanks for this. Where can I locate a vendor to purchase a circuit board?
Hi, where do I find the circuit board please?
Where can I get the circuit board?
Anyone had any luck on finding the circuit board to buy?
Excellent information, just need the circuit board or the schematics.
Por fabor no bate si ustedes puden reparar o me venden.el integrado..que parese estar malo yo estoy en Colombia Barranquilla atlántico tef 3044645318..un informe se agradese
Por fabor una repusta
