This guide will teach you how to replace the spring in the button of your blender.
Place the blender to the side.
Remove the two highlighted screws with a Phillips #2 Screw Driver
Gently pull off the top.
Remove the highlighted screws.
Pull out the highlighted spring.
Now wash the button with soap and water, and follow the guide backwards to reassemble.
Any idea where to get a replacement switch for this model? Mine is FRIED! Thank you!
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
turns out it was a security torx. how annoying.
