The interior heating coils in your Ninja Foodi SP101 are mainly used for the toast and broil features of the oven. The coils reach extreme temperatures, so ensure that they are completely cool and device is disconnected from power before continuing.
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
Flip the device upside down and open the bottom panel.
Remove the 3 x philips #1 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
Lift the handle and pull the side panel out.
Remove the handle side panel.
There's a Torx screw inside the oven you need to remove as well...
Using a Phillips #1 screwdriver, remove the six 8mm screws on inside of the handle-side panel.
Flip the device to the control panel side.
Remove the single 10 mm screw with a Phillips #1 screwdriver.
Remove the control panel by sliding it up and out.
Remove the four 8 mm screws behind the control panel using a Phillips #1 screwdriver.
Remove two more screws located behind the motor.
Lift the coils up and outward for removal.
Can you tell me the heating element part number or how can I order mine the cristal
Broke and can not used it like this pls
Help
Where do you get the replacement element?
Did you find out if you can get the element anywhere?
Has anyone found a viable replacement element being sold?
Same question. The ones on mine say 230V 335W.
