Ninja Foodi SP101 / FT102A Cooling Fan Replacement
  1. Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Feet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
  2. Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black lever bar.
  3. Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Side Panels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
  4. Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device upside down and open the bottom panel.
    • Remove the 3 x philips #1 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
  5. Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
  6. Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the handle and pull the side panel out.
    • Remove the handle side panel.
  7. Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Release Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Release Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw from the electronics assembly plastic frame as shown. Don't drop the screw upon removal!
    • Lift the assembly slightly such that the screw to the metal tab that holds the fan in place can be accessed. Remove it with a Philips screw driver. Do not drop it. Use help holding up the assembly if so needed. Do not bend the tab.
  8. Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Remove Old Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Remove Old Fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Remove Old Fan: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black cooling fan by sliding it out. There are retaining tabs on the sides that need to be lifted to release the fan.
  9. Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Disconnect Old Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red cable that attaches the cooling fan to the motherboard. Squeeze the tab on the red connector and pull slightly at the same time to release it.
  10. Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Install New Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Install New Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 / FT102A Cooling Fan Replacement, Install New Fan: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cooling fan and replace it with a new fan of equal size and type: 60 x 60 x 15 mm, 12V DC. Carefully compare for fitment.
    • When the fan comes without a connector or the wrong connector, cut the connector off the old fan, leaving enough wire-length on the connector side of the harness. Strip the ends with a stripping tool or the like.
    • Solder the wires together and apply appropriate insulation. Red to red (+), black to black (-) Shrink wrap works well.
    • Ensure that the replacement fan is an INTAKE fan, pulling air into the box. (A prior version of this guide had the direction reversed).
    • A good replacement candidate of the fan can be bought from www.digikey.com. Part number 259-1802-ND. It is a Sunon fan of higher quality than the Hongfei HD-6015L12R fan that is replaced. This fan is confirmed to blow air into the same direction as the old fan.
    • Insert the new Sunon fan with the label facing into the control electronics compartment. The wires need to exit the fan housing on the top when inserted. Dress the wires to ensure that they do not touch the (hot) metal housing or heatsink. Use tie wraps if needed.
    • Reassemble oven in the reverse order as in the first steps.
    • Test the oven for good functionality. The fan will come on after a few minutes of (pre-)heating so wait until that occur. Ensure the fan air is being pulled into the unit. If installed backwards, the Foodi will stop after about 10 minutes with ERROR 1. A good test is to run a complete cycle for 15 minutes on Air Fry at 425F.
ben
crwdns2935283:001/30/24crwdne2935283:0
473 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-4, McMurrin Spring 2024 crwdns2935289:0Utah Tech University, Team 1-4, McMurrin Spring 2024crwdne2935289:0
UTAHTECH-MCMURRIN-S24S1G4
crwdns2947412:09crwdne2947412:0
Can you provide the model # of the fan you replaced with ; and for Steve Hemphill did you pull the fan out yet ? what was the old fan make/model, maybe Amazon has one.
Joseph V - crwdns2934203:0crwdne2934203:0
This is a 60x60x15mm 12 volt fan. I purchased one on Amazon, it doesn't really matter which one as long as it's the correct measurements. The white plastic 2 pin connector should work in the stock board, but you can swap the connector from the old fan onto the new one easily by depressing the two locking tabs on the electrical pins. Make sure the orientation is correct, this is an intake fan and should be pulling air into the case. If the fan is installed backwards, the unit will overheat.
Ian Mittelstaedt - crwdns2934203:0crwdne2934203:0
I just did this repair, and used the Noctua NF-A6x15 FLX fan (Amazon link: https://www.amazon.com/dp/B0DJMHV4RP ) and it's vastly quieter.
However, I was getting the overheat (Error 1 Call Cust Srvc) messages when cooking anything that took over 5 minutes.
I just re-read Ian's comment, and I'm pretty sure I have the fan installed backwards (it's exhausting rather than pulling cool air into the case).
Will reverse the installation and report back.
Mike D - crwdns2934203:0crwdne2934203:0
I think I see why I was confused. Step 11 says "Ensure the fan air is blowing out of the unit." and that's what I did.
However, Ian M's comment says "Make sure the orientation is correct, this is an intake fan and should be pulling air into the case. If the fan is installed backwards, the unit will overheat."
I followed Step 11 and I'm definitely getting overheating, so I think Ian M may be correct.
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 212
crwdns2942667:0crwdne2942667:0 3,663
