Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement
  1. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Valve Tubes: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Valve Tubes: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
    My Ninja has T10 Security-head screws. Several are recessed quite deep in the bottom cover. I found a set of 60mm long security torx bits on Amazon for around $12 The extended length worked great for the deep recessed screws.
    Mike Stroven - crwdns2934203:0crwdne2934203:0
  2. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Water Heater: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Water Heater: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
  11. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Hot Water Tubing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze connector and pull tubing away from heater.
    • Inspect tubing for damage and/or weak spots and replace if necessary.
Kyle Gustafson
crwdns2935283:011/04/18crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 crwdns2935289:0UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018crwdne2935289:0
UMASSD-GULBRANDSEN-F18S5G4
what size tubing does this require?
Lemmiwinks Rules - crwdns2934203:0crwdne2934203:0
Hi Kyle,
Thanks for this. I’m having trouble getting the top to separate. Any suggestions?
S. D. G. - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,379
