Nikon D5100 LCD Replacement
Liz
crwdns2944107:0crwdnd2944107:0Lizcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 21, 2022crwdne2944111:0
15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937595:0crwdne2937595:0
crwdns2942287:0crwdne2942287:0
The LCD unit is the main component of the digital display on the D5100. This guide will teach you how to remove and replace it.
crwdns2944105:0crwdne2944105:0
  1. Nikon D5100 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D5100 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the four screws around the perimeter of the LCD panel.
    Possible "000" (smaller than "00") size screw driver. My 00 was too big.
    Peter XYZ - crwdns2934203:0crwdne2934203:0
  2. Nikon D5100 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a fingernail or the flat edge of a spudger inserted into the seam, separate the LCD bevel from the main panel body.
  3. Nikon D5100 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D5100 LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to remove the ribbon cables on the LCD's circuit board by flipping up their plastic lock-bars and removing gently pulling them out of their ports.
  4. Nikon D5100 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect the 16-pin cable by gently pulling it upward, away from the circuit board, until it is removed from its port.
  5. Nikon D5100 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the 3 wires (red, yellow, and black) connecting the LCD board to the main camera body.
    • Soldering/desoldering presents potential for device damage and burns. Take all necessary precautions, and always solder/desolder in a well-ventilated workspace.
    Solder Iron tool should had been at the very top. :D
    It might have been a better idea to pry-off the board first and then de-solder the contacts. Or at least note that high heat is bad for LCD screens.
    It’s very possible that applying the soldering iron to the board, while still attached to the back, caused the LCD to lose its color alignment and darken the display.
    Franky - crwdns2934203:0crwdne2934203:0
  6. Nikon D5100 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D5100 LCD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The LCD assembly can now be fully separated from the main camera body.
    • Remove the plastic bezel and metal bracket from the LCD itself to complete the removal process.
crwdns2935229:010crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Liz
crwdns2935283:004/25/14crwdne2935283:0
1,428 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-54, Amido Spring 2014 crwdns2935289:0Cal Poly, Team 10-54, Amido Spring 2014crwdne2935289:0
CPSU-AMIDO-S14S10G54
crwdns2947412:07crwdne2947412:0
Thank you so much! My camera was dropped . And yelow and black wires came off. Now i will try to fix it.
What is the functions of these wires?
Ilia - crwdns2934203:0crwdne2934203:0
Thanks for this Liz.
Removing the broken LCD from my Nikon D5100 seems like something I can do now!
I am unsure ?how to do the soldering bit to attach the new LCD, ?where to attach the wires...
Any help is welcome
Felipe Castro - crwdns2934203:0crwdne2934203:0
I was able to fix it, thanks to you guys. But the colors that came on the, LCD are weird. At least I can see the image.
Arline Osuna - crwdns2934203:0crwdne2934203:0
It’s very possible that applying the soldering iron to the board, while still attached to the back, caused the LCD to lose its color alignment and darken the display. I made the same mistake.
Franky -
I am having trouble reconnecting the 16-pin cable to the circuit board. Do you have any tips?
Lyle Ralston - crwdns2934203:0crwdne2934203:0
Thank you! I had talked to a camera shop and they said the cost of the crystal would be so much I should buy a new camera…. The crystal was 54.00 and i just need my personal time and labor. THANK YOU!!!
bethhite2005 - crwdns2934203:0crwdne2934203:0
want to replace my D5100 LCD screen as it's already dying and I can't find D5100 LCD screens but found countless D5200 LCD replacement and just want to ask if the d5100 and d5200 share the same LCD?
they're the same 3" 920k screens and look the same too, just want confirmation as I don't want to buy a screen that won't fit mine 😅
Janarthanaan Thamizh Selvan - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 13,010
