Nikon D40 Mainboard Replacement
crwdns2942287:0crwdne2942287:0The mainboard controls all of the software on the Nikon D40. A faulty mainboard can cause problems that will require a new board. This guide will show you how to replace the camera's mainboard.
crwdns2944105:0crwdne2944105:0
Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
Worth mentioning, the top circled screw was a 6mm on my camera. The other 3 were 3mm.
While pulling the bottom down, remove the back of the camera.
Remove the solder connecting the red wire to the mainboard.
Desolder the 4 smaller wires near the bottom of the mainboard.
Use the plastic opening tool to release the ribbon cables attached to the mainboard.
Remove the five 3.0mm Philips #1 screws holding the mainboard down.
Lift the mainboard up to reveal the final connection.
crwdns2935229:05crwdne2935229:0
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
