Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
  1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
    This doesn’t work!!! I have two S800C cameras, and #1 there are FIVE SCREWS instead of four; one is on the lens side of the case. But once those five screws are out, the LCD will still not separate from the main body. Something in the vicinity of the shutter button is holding the two together. Both cameras are the same in that respect, and because I fear damaging *both* the body and the screen if I try to force it, I’m stuck tight wishing someone could clue me in as to what perhaps simple thing is left out of these instructions.
    The same issue exists with every single guide in this series—the camera WON’T COME APART with the steps shown.
    Brian Capouch - crwdns2934203:0crwdne2934203:0
    The same happened to me. I can't open it because one corner is stuck to the camera near the hdmi port.
    Oliver Gayner - crwdns2934203:0crwdne2934203:0
    There's a screw that is hidden on the top corner. It's under the gray trim that surrounds the buttons. Trim has little tabs, and glue.
    renzomv - crwdns2934203:0crwdne2934203:0
Ilyasah Muhammad
crwdns2935283:001/30/18crwdne2935283:0
234 crwdns2915208:0crwdne2915208:0
Baylor, Team S2-G6, Johnson Spring 2018 crwdns2935289:0Baylor, Team S2-G6, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S2G6
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 551
