This guide uses the lens assembly guide to get the camera apart. Once you have finished with the lens assembly, getting to the casing is fairly easy.
Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
On the thumb grip, remove the one 4mm PH00 Philips screw.
With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
Open the flash and use a plastic opening tool to pop the tab under it as shown.
Now pull the casing apart.
The tripod attachment may fall out on its own, or you will need to pull it out.
Unplug the two ribbon cables to completely detach the back.
With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
Remove one 5mm PH00 Philips screw
With all the screws out, the metal plate should simply lift off.
With the metal plate off, unplug this ribbon cable from the motherboard.
To remove the flat-topped connector, you simply lift it up to unplug it.
To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
With the support screws out, you can simply slide the assembly out of the casing.
With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
Remove the five PH00 screws surrounding the lens.
Separate the lens casing from the front.
To reassemble your device or to attach a new lense, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
