This guide shows the location of the batteries and the memory card. It also helps to benefit how to open the door latch.
The batteries are located on the bottom of the device on the right hand side. To open the compartment press the button in and slide it towards you and pull the door open.
The memory card is located next to the batteries. To remove the memory card press it in and it should pop out.
I need help - my Coolpix L610 battery door will not close and lock.
Door will not close and stay closed
gmurphree1@aol.com - crwdns2934203:0crwdne2934203:0
