This guide shows how to replace the motherboard and battery housing. This can be replaced if there are any issues with the battery connectivity or the board blows out.
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
Open the HDMI flap to remove a 5.5mm screw.
Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
While twisting, pry apart the shell to split the camera in half.
Place the pry tool under the black latch. Lift gently until the latch flips up.
Gently pull the ribbon away from the latch.
How to check the rear part my b700 will turn ON when i disconected the 2 ribbons
Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
Remove the single 6mm screw.
The screw to unscrew on the bottom left seems to not exist or is covered by a foam which is as large as the grey area around in the picture.
Also from this step to the next the golden cover got removed it seems.
I removed the left screw on the golden cover as well.
Insert the pry tool under the latch and gently lift up to remove the ribbon.
Move the ribbon out of the way to reveal the hidden screw.
Lift the button assembly gently to give access to remove the 4mm screw.
On the top of the camera, remove the 6mm screw.
With the spudger tool gently pry off the white tap holding in the bracket.
Use the same tool to remove the glued-on ribbon.
Gently lift up the button assembly to slide the bracket out.
With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
Use the metal spudger to open the latch to remove the ribbon.
Use the Phillips screwdriver to remove the single 6 mm screw.
Gently lift the button assembly. Slide the motherboard out from the shell.
Desolder the black, gray, and white wires from the motherboard.
Nikon b700 all sorts part demegs
