This guide will show you how to remove the monitor assembly on the Nikon Coolpix A900.
If the monitor on your camera suffers a hard drop, water damage, or gets to scratched up, you may want to replace your monitor.
This guide is relatively simple, but be sure to have a container for small parts ready.
Orient the camera so that it is upside down, with the lens facing towards you.
Slide the battery door lock left to unlock it.
The battery door will automatically open.
Good addition of different conditions of the camera (camera is dirty)
Slide the yellow tab up to release the battery.
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
Turn the camera on its side, with the lens facing away from you.
Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
Place the camera upright with the lens facing away from you.
Move the monitor down, and remove two 4.4 mm screws.
After dropping the camera image with small apertures appears
Remove the two black 2.5 mm screws from the monitor bracket.
Is there anywhere I can buy a replacement screw for this part? I have lost one of these screws
Return the monitor to the closed position.
Gently open the rear case.
Place the camera lens down, while supporting the rear case.
Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
With the ribbons disconnected, you can now remove the rear case.
Set the rear case screen down.
Remove the two 2.5 mm black Phillips #00 screws.
Separate the rear case from the monitor assembly.
Hello. Excellent help. Where can I get a new screen for my Nikon A900 when the screen glass is broken and the screen is not clear, please?
Where did you get a new monitor for your camera?
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
This is excellent but where would you get a new 3” monitor?
Have you tried AliExpress or Ebay?
photower -
