Nikon 1 J3 LCD Screen Replacement
  1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon 1 J3 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
    Achtung bei der Anleitung fehlt das entfernen von 2 Schrauben. Dann kann man die Plastikplatte ohne biegen und brechen abnehmen und zwar unter der Klebeplatte auf der Seite nach der man aufklappt. (ist festgeklebt)
    Jan Birthelmer - crwdns2934203:0crwdne2934203:0
    Tuto misses 2 screws hidden behind a small plastic cover on the button side of the camera.
    Once these 2 screws are removed, the entire bezel removes easily.
    Pierre-Henri Francois - crwdns2934203:0crwdne2934203:0
  2. Nikon 1 J3 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Nikon 1 J3 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Nikon 1 J3 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
Austin Lackey
crwdns2935283:009/26/17crwdne2935283:0
479 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G4, Passmore Fall 2017 crwdns2935289:0USF Tampa, Team S11-G4, Passmore Fall 2017crwdne2935289:0
USFT-PASSMORE-F17S11G4
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - crwdns2934203:0crwdne2934203:0
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - crwdns2934203:0crwdne2934203:0
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,359
