Nikon 1 AW 1 Buttons Replacement
Lester Rodriguez Piti
crwdns2944107:0crwdnd2944107:0Lester Rodriguez Piticrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0December 28, 2016crwdne2944111:0
crwdns2931273:0crwdne2931273:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Sometimes the only thing wrong with your camera is a broken button that won't let you turn it on. This guide will show you how to replace those problematic buttons.
crwdns2944105:0crwdne2944105:0
  1. Nikon 1 AW 1 Buttons Replacement, Buttons: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement, Buttons: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement, Buttons: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
  2. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
  3. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
  4. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
  5. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
  6. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
  7. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 AW 1 Buttons Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to lift off the top panel.
  8. Nikon 1 AW 1 Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you needed to replace any buttons, you may now do so by pulling them off.
crwdns2935283:010/04/16crwdne2935283:0
373 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-4, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 3-4, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S3G4
What if the flash button is not working? How will i open or fix it? Flash does not pop out
Noel Marantan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 859
