These step by step instructions will allow you to easily remove the LCD screen on the watch and replace it with a new one.
First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
Carefully separate the watch by pulling the band away from the main board.
Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
Carefully use the blue plastic opening tool to pry the main board out of the front panel.
Use the blue plastic removal tool once again to carefully remove the screen.
Pull the plastic piece that is highlighted in the picture out from the back of the screen.
For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
Hello,
Thanks a lot for these informations. I would like to know how the LCD is maintained (glue, clip ???) Carine D
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
hello do you know where I can find a replacement screen ?
Thank you
I googled the part number on the screen
