Use this guide to replace a malfunctioning battery. This replacement guide requires a Soldering Iron, it would be very helpful to heat the iron up before starting this guide, this process can take 3-4 minutes. You should refer to iFixit's soldering guide to help with the desoldering/soldering process.
Using your finger, open the plastic tab to the right of the rear-facing camera.
Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
Using your finger, remove the SD card by pressing down on top of it (toward the bottom of the device) until you hear a clicking sound.
Once the card pops out, use your finger to pull the card completely out of the SD card slot.
Remove the 5 mm screw using the Phillips PH00 bit in the iFixit metal Screwdriver.
Use the plastic opening tool to separate the back panel by carefully sliding the narrow end of the tool between the front glass and back panel.
Use a second plastic opening tool to help pry the front glass from the back panel.
Use your hands to completely separate the rest of the front glass from the back panel.
Remove yellow tape with a black edge that covers the red, white and black wires.
Remove the white masking tape covering the red white and black wires.
Desolder the red, white and black wires on the left side of the motherboard.
Use the flat end of the spudger to carefully separate the smaller, silver battery square from the digitizer.
Use the flat end of the spudger to carefully separate the large battery from the digitizer.
Clear & concise. Nice job! Even I could follow it!! ;-)
Excellent guide, easy to follow, very concise, very good photographs. Thank you
Donde puedo encontrar una batería
jhtrtih0rthk[riiyih0riyihtri0okhi00rtiyro-yiy0iy[oytrkoih0it
9turiyrithjhtohtitujhtprit0ryryt9it[thohotjhri0-trhjirt-nm otjhphyuhjr0i trirt-t
jtiophkr
Aaron carlin - crwdns2934203:0crwdne2934203:0
