Newport e360 Exhalation Flow Sensor Replacement
  1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
  2. Newport e360 Exhalation Flow Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
  3. Newport e360 Exhalation Flow Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
  4. Newport e360 Exhalation Flow Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
  5. Newport e360 Exhalation Flow Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
  6. Newport e360 Exhalation Flow Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
Lauren Ochoa
crwdns2935283:004/13/20crwdne2935283:0
165 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G21, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G21, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G21
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - crwdns2934203:0crwdne2934203:0
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 652
