New Nintendo 3DS XL 2015 Circle Pad Replacement
  1. New Nintendo 3DS XL 2015 Circle Pad Replacement, Circle Pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure device is turned off and the stylus and game card are removed.
  2. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device so that the back cover is facing you and locate the two screws at the top of the back cover.
    • Using the Phillips #000 screwdriver, loosen the screws on the back cover.
    • The screws do not come out, but may be loosened to allow for the back cover to be removed.
    • Gently pry the tabs on the side of the device with the metal spudger or your thumbnail and lift off the back cover.
  3. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the microSD card by pushing it in, the card should automatically pop out.
  4. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the battery, hold the device with the battery facing up in one hand, with a finger securely gripping the lid of the device, and gently flip the device over to your other hand. The battery should fall into your hand.
  5. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two rubber bumpers on the back of the device with a thumb tack.
    • Using the Phillips #00 screwdriver, remove all 8 of the screws holding the bottom cover to the motherboard.
    • Lift off the bottom cover, being sure not to disconnect the two ZIF connectors for the L/R buttons on the back of the device.
    2 of My Screws are un-openable & its like sealed it cant be like this forever & my circle pad is kinda faulty.
    George - crwdns2934203:0crwdne2934203:0
  6. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the two screws holding the circle pad in place.
    • Be sure to keep these screws separate from the bottom cover screws, the circle pad screws are slightly longer and only compatible with the circle pad.
    • Lift the circle pad out of its place to expose the ZIF connector.
  7. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tip of the spudger, gently lift off the lid of the ZIF connector to release the circle pad cable.
    what am i supposed to do to get the rest of it off? there's a whole part of the circle pad missing in these steps.
    Garrett Schilling - crwdns2934203:0crwdne2934203:0
  8. New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 New Nintendo 3DS XL 2015 Circle Pad Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the new circle pad assembly and insert the cable back into the open ZIF connector and close it using the spudger.
    • Ensure the internal component of the circle pad is correctly oriented with a small screwdriver or spudger.
    • Gently place the new circle pad back into its place and secure with the screws.
    • We had to try this step a few times before we were able to orient it correctly. Try to make sure that the circle pad does not move the internal assembly once it is inserted.
    No where does this Mention the 3 different sized screws and where they go after disassemble.
    Daniel Castro - crwdns2934203:0crwdne2934203:0
    Great guide, it could also do with how to replace the rubber top half of the circle pad too. I've also done this. From the photo in step 8, there's a thin split plastic washer underneath the underside of the circle pad still attached to the 3DS. You can carefully slide this washer out through it's split, then you can remove the upper half of the circle pad by carefully sliding one prong of the C shape through the hole, sliding it through going round, then the other prong will side out and it will be removed. To replace, do it in reverse, but it's very fiddly sliding the split washer back into place, but it can be done with tweezers. On all 3DSs I've opened, the notch on the C shape on the underside is facing down towards the bottom, on this photo it's shown facing the top, but I don't know if it makes any difference. This applies to both old and new 3DS XL and I imagine applies to others too.
    Andrew - crwdns2934203:0crwdne2934203:0
    Thanks Andrew. This comment is super helpful and should be included as part of the guide.
    Robert Becker -
crwdns2935229:025crwdne2935229:0
Tori Anderson
crwdns2935283:002/20/18crwdne2935283:0
913 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S5-G2, Baddour Spring 2018 crwdns2935289:0University of Memphis, Team S5-G2, Baddour Spring 2018crwdne2935289:0
UM-BADDOUR-S18S5G2
crwdns2947412:07crwdne2947412:0
oh my gosh this is the best guide my grand-son and i fixed his sons 3DS he is so happy
Andrew Dahm - crwdns2934203:0crwdne2934203:0
2 of my motherboard screws can’t open with my newly ordered philips 00 screwdriver. the screws insides look like circles rather than crosses.
Thanks for the guide! I needed to replace the internal component of the circle pad as well, as the rubber pad came off mine. @thirtyninester 's comment on Step 8 helped! Thanks to that comment as well!
Justin Alex - crwdns2934203:0crwdne2934203:0
Help! I'm stuck on Step 5. Upper leftmost screw refuses to come out and I can't tell whether I've worn down the screwhead or the screwdriver. Removal advice please. Otherwise my only recourse may be to replace the entire system. Just transfer everything datawise and be done with it. It'd be a shame if I had to admit I spent $90+ on parts & tools for nothing just for it to come to this. And I don't even want to think about how much a new unit will cost on the secondhand market. I'll be lucky to find one at it's original MSRP.
Matthew Conklin - crwdns2934203:0crwdne2934203:0
Hey,
you could try to use a slightly larger screwdriver and see if the screw comes out. Otherwise you have to drill the screw out which is probably still better/cheaper than replacing everything. Hope this helps!
Henrynaja -
I'm having the exact same issue on the exact same screw. Have you had any success getting it out?
Macade Allen -
dose it come with new ribbon cables or not because a friend stuffed the cable connecter
Jasper Dalbroi - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 31
crwdns2936753:07crwdne2936753:0 174
crwdns2936753:030crwdne2936753:0 783
crwdns2942667:0crwdne2942667:0 38,625
