Nest Learning Thermostat 2nd Generation Base Motherboard Replacement
  1. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your Nest Thermostat, be sure that your HVAC system is powered off.
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
  2. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remember to turn off the power to your HVAC system and the thermostat.
    • Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
    HOW do you disconnect the wires? I can't get them out!
    Beverley Brown - crwdns2934203:0crwdne2934203:0
    Same here. It is like the springs are in a stuck position
    Bill Redfield - crwdns2934203:0crwdne2934203:0
    I also can not dis-engage the wires. Feels like the springs are frozen closed.
    Hold down the button on the end and the wire should be able to slide right out.
    Amber - crwdns2934203:0crwdne2934203:0
    Yes, the button on the end of the wires is stuck in the down position. Tried pushing with my fingers and several smaller tools- they appear to be frozen in the down position.
    Garet Ten Cate - crwdns2934203:0crwdne2934203:0
    If you hold the buttons down while pulling the wires, they'll come right out and the button springs reset.
    Dan - crwdns2934203:0crwdne2934203:0
  3. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from wall: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
  4. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unsnap the base from the trim plate (if used) using a plastic opening tool.
  5. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from back of base: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from back of base: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the base over.
    • Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
  6. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Opening base: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Opening base: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the base mother board open from the side using a plastic opening tool.
  7. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The base mother board is only held together by light adhesive.
    • Pry the baseboard from the bottom using the flat end of a spudger.
Rachael Deptula
crwdns2935283:009/03/14crwdne2935283:0
1.126 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 11-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S11G5
crwdns2947412:08crwdne2947412:0
Would like to know where I can get just the base motherboard.
wesbug - crwdns2934203:0crwdne2934203:0
Where can we purchase replacement parts?
brettspradley - crwdns2934203:0crwdne2934203:0
i want the baseboard.. where i can buy? pls help...
john gemora - crwdns2934203:0crwdne2934203:0
Yep, my base unit lasted exactly 8 days, then it shorted out. The furnace repairman said he has seen it a couple of times, the base unit can't handle the current needed by the furnace so it goes poof. Back to Honeywell...
bbolen - crwdns2934203:0crwdne2934203:0
No replacement parts from Nest, my base unit died and I have perfectly working thermostat but am forced to buy a new one cause I can't get the base unit on its own.
Adrian Ma - crwdns2934203:0crwdne2934203:0
I have no clue why people like their thermostats to the degree that they do.. I am both an A/c professional and an Engineer. They use what is called an SCR or silicon controlled rectifier for their switching instead of a tiny relay. An SCR is very sensitive to a spark or voltage spike. Yes the thermostat is pretty cool and has some nice features. It is advanced electronics but using SMC's or Surface Mounted Components?? . Maybe that would work well in a shielded component. But NOT in something that is connected to long external wires. The consumer bought warranty is only one year. I have seen too many issues in the field with their overpriced toys. Not having parts for this Chinese made thermostat? Priceless.
Jon Reid - crwdns2934203:0crwdne2934203:0
Hey Jon, I’m trying to repair my parent’s 2nd Gen Nest. It sends out “heat” and “cool” signal at the same time. Anyway I can replace a component on the motherboard?
Lizik -
Good post. Wish I had read before I got a Nest thermostat. What would you recommend as a good alternative? I hate when you can't replace simple components and parts cheaply and quickly. What the !&&*.
doughboy1338 -
crwdns2942667:0crwdne2942667:0 93,449
