Nespresso Inissia Disassembly
Léon Witteman
crwdns2944107:0crwdnd2944107:0Léon Wittemancrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 21, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
The machine in question is from Magimix. The other available version (Krups) is very similar and this guide should be applicable to those.
First of all consider your machine’s warranty (usually 2 years), after (partial) disassembly you’re not eligible for warranty anymore.
Unplug the machine and find a workplace that you’re not afraid to scratch, which I found out the hard way.
crwdns2944105:0crwdne2944105:0
  1. Nespresso Inissia Disassembly, Emptying the machine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Inissia Disassembly, Emptying the machine: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all water from the system. (From the Nespresso manual.)
    • image 2: exploded view of the machine. Source: buyspares.com
    cuando pulso los botones,se encienden los dos haciendo pausas cada tres encendidos ,y no paran que puede ser el motivo ??, gracias
    moy5099 - crwdns2934203:0crwdne2934203:0
    Prueba esto: Apague la máquina, mantenga pulsado el botón derecho (vaso grande) hasta que el botón izquierdo parpadee 3 veces, listo. Si esto no funciona: Apague, desenchufe, espere 1min, enchufe y continúe como arriba.
    Si tienes mala suerte, esta es la causa: Nespresso CitiZ Kondensatoren tauschen
    VauWeh -
    Nello spaccato manca la parte che sta a contatto con le capsule e la leggenda con i numeri di riferimento dei pezzi.
    Riccardo Ricci - crwdns2934203:0crwdne2934203:0
  2. Nespresso Inissia Disassembly, Remove the first part: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Inissia Disassembly, Remove the first part: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull straight forward with a fair amount of force.
    • Once you hear a click, pull the part straight down. This should go easilly.
    What is the name and part number of this part? Where can I buy a new one?
    VERONICA THUESEN - crwdns2934203:0crwdne2934203:0
    NN-300134 1-1-J made of ABS
    Markus -
    Lo siento no lo se, hay piezas que no estan a la venta sencillamente porque la demanda de piezas es muy pequeña o inexistente.
    Carlos López (España - Spain) - crwdns2934203:0crwdne2934203:0
    Bonjour
    Je ne parviens pas à remettre cette pièce en place. Une technique particulière ?
    Merci d'avance
    Nicolas - crwdns2934203:0crwdne2934203:0
    Ninguna, tecnica en especial, tan solo va encajada, si que es verdad que me costo un poco encontrar la posicion correcta, te aconse uses una linterna para ayudarte.
  3. Nespresso Inissia Disassembly, Remove the handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Inissia Disassembly, Remove the handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T20 torx bit (star-shaped). A screwdriver that fits should work fine.
  4. Nespresso Inissia Disassembly, Remove side cover 1/2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove side cover 1/2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove side cover 1/2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Close the cup-holder firmly.
    • Photos 2 and 3, push the screwdriver in and wiggle a bit to undo the clips. There's a total of 4 clips.
    Il serait bien de préciser de quel couvercle latéral on parle : le droit ou le gauche ? Merci.
    Gilles Guérin - crwdns2934203:0crwdne2934203:0
  5. Nespresso Inissia Disassembly, Remove side cover 2/2: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove side cover 2/2: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove side cover 2/2: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the notch lines up.
    • Pull the cover away. Once there's a little room, move your fingers up a bit and pull on the sides.
    This is quite delicate, scary and slow! There are more clips and the side can get stuck on the metal lugs that stick out the side. You may have to ease the plastic cover over them.
    Terry Cunnane - crwdns2934203:0crwdne2934203:0
    Use the handle, not pliers to align.
    Bob - crwdns2934203:0crwdne2934203:0
  6. Nespresso Inissia Disassembly, Remove other side cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Inissia Disassembly, Remove other side cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat on the other side
    La photo avec la main me semble trop zoomée. Un plan plus large serait plus explicite. Merci.
    There are way more clips to disengage.
  7. Nespresso Inissia Disassembly, Remove the white clip: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
  8. Nespresso Inissia Disassembly, Remove power wires: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove power wires: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove power wires: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the device first! Remove ground, live and neutral wires.
    • Remove the whole wire from its slot.
    Stroom nooit laten zitten bij uit elkaar halen, dus dit had vóór stap 1 al gemoeten.
    paul - crwdns2934203:0crwdne2934203:0
    De witte plastiekjes zijn afdekkapjes. Het is beter om telkens het kleine dekseltje van het witte plastiekje te openen, om vervolgens de onderliggende klem los te trekken.
    P-308 - crwdns2934203:0crwdne2934203:0
  9. Nespresso Inissia Disassembly, Remove the water tank seat: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the clips using a thin screwdriver
  10. Nespresso Inissia Disassembly, Remove inner housing first side: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove inner housing first side: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove inner housing first side: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry loose on these four spots and remove.
    When your machine is leaking, this is the right moment to diagnose it once this step is done. I suspect most pressure is on the parts when using a new cup. Screw back the lever to insert a new cup. Reconnect the power cord and put the water tank seat back on so the water container can be used.
    When putting the machine back together this point is obviously also the right time to test if everything is working (again) as expected.
    Ferry de Boer - crwdns2934203:0crwdne2934203:0
  11. Nespresso Inissia Disassembly, Remove inner housing second side: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove inner housing second side: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Remove inner housing second side: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Photo 1: Using leverage, pull up.
    • Photo 2: unclip the two clips on the inside of the cover.
    • Photo 3: turn over and lift the cover off.
    L'étape 11 est délicate à réaliser. Je n'y suis pas arrivé, j'ai cassé une pièce => Poubelle
    Alpes Tour - crwdns2934203:0crwdne2934203:0
    Hola Alpes, Por desgracia este paso no es sencillo , es el mas complicado de todo el desmontaje, y alguna vez se rompe algun anclaje, lo he podido constatar en varias que he desmontado similares
    De plus, au remontage, il faut veiller à ce que "le tout" s'emboîte bien au niveau de la zone située près de la lame du tournevis. Sinon, "le tout" est trop haut et va empêcher le positionnement correct du "premier côté". La manœuvre de (ré)emboîtement demande assez bien d'effort.
    JPKuypers - crwdns2934203:0crwdne2934203:0
    Traduccion de JPKuypers: Además, al volver a montarlo, asegúrese de que el "todo" encaje en la zona próxima a la hoja del destornillador. De lo contrario, el "todo" queda demasiado alto e impedirá la correcta colocación del "primer lado". La maniobra de (re)montaje requiere bastante esfuerzo.
    Je ne comprend pas quelle pièce vous cherchez à retirer? Si on procède de la manière décrite, il n'est pas possible de ne pas casser du plastique.
    Ahah - crwdns2934203:0crwdne2934203:0
    Traduccion
    ¿No entiendo qué parte está intentando eliminar? Si procedes como se describe, es imposible no romper el plástico.
    Je ne comprend pas quelle pièce vous cherchez à retirer? Si on procède de la manière décrite, il n'est pas possible de ne pas casser du plastique. En effet des pièces supplementaires sont à enlever avant, notamment à l'intérieur de la structure sur le haut de la figure 1. Le tournevis photo1, tel qu'il est positionné fait pression sur la même pièce plastique d'où casse certaine si vous forcez!
    Traduccion
    ¿No entiendo qué parte estás intentando quitar? Si se procede como se describe, no es posible evitar romper el plástico. Primero hay que quitar otras piezas, sobre todo dentro de la estructura de la parte superior de la figura 1. El destornillador de la foto 1, tal como está colocado, ejerce presión sobre la misma pieza de plástico, ¡que se romperá si lo fuerzas!
    No te queda mas remedio que realizar palanca para poderdesmontar esta parte de la maquina.
  12. Nespresso Inissia Disassembly, Remove the lever seats: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Inissia Disassembly, Remove the lever seats: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push on the assembly, front to back, to free up the lever seats. Then pull them out.
    Hola y para volver a ponerlas? Yo desarme hoy la mia y no consigo ponerlas como estaban
    Cristian J - crwdns2934203:0crwdne2934203:0
    Has de empujar hacia abajo para que te permita que se inserten https://www.youtube.com/watch?v=qUiKj5Ks...
  13. Nespresso Inissia Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top part can be removed by having the metal pins follow the slots in an L shape.
    Il porta capsula può essere rimosso sganciando le due linguette;
    sotto c'è un O-ring che più perdere acqua in pressione che poi fuoriesce sotto la macchina in funzione!
    Qualcuno sa dove posso trovare l'O-ring di ricambio???
    Grazie!
    Devis Mariotti - crwdns2934203:0crwdne2934203:0
  14. Nespresso Inissia Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open both clips on one side of the spout, then both on the other side.
  15. Nespresso Inissia Disassembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mark one of the black leads for proper reinstallation.
    • Remove the yellow and brown wire.
    • And the white connector.
    When putting the machine back together make sure the spring on the bottom of the pump is propely back in the seating. If not the machine will resonate like crazy.
  16. Nespresso Inissia Disassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wiggle loose the last bit of black plastic.
    • Pry off the white and black water lines.
  17. Nespresso Inissia Disassembly, Removal of plastic U-pipe for O Rings within.: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Removal of plastic U-pipe for O Rings within.: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly, Removal of plastic U-pipe for O Rings within.: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • These clips are tricky to remove. The plastic rectangles housing the wire clips are part of the U-pipe. Bear this in mind when detaching the U-pipe from the two other (pump and boiler) pipes - which have cone shaped flanges; easy to push U-pipe faces onto, hard to detach.
    • Using the perspective of Photo1 for reference, for ease of working, ensure the background is down towards the floor, and ensure the metal pipe is braced, directly or via the boiler resting on a non-slip surface like a rubber mat or carpeted floor. Set-up the equivalent if working from the pump end of the U-pipe.
    • Push a 2.5mm thick pointed tool (rod or flat) into the wire loop that emerges from the centre-bottom of the plastic face. Do not make the loop emerge farther, but you can widen it <1mm with a suitable width screwdriver.
    • Left and right shoulders of the wire clip are to be pulled apart as far as the plastic face will allow. Start by inserting (and leaving in place) similar 2.5mm-3.5mm thick pointed/tapered tools between the outside edge of the plastic face and the exposed wire ends. Insert near each shoulder.
    • With the wire clip being held apart in three places, check that the wire in the centre of the plastic face is not still hugging the pipe but is just proud of the rim of the cone-flange. Another pointed tool may be needed to manipulate the rest of the wire over the edge of the cone-flange.
    • With the perspective of photo1 (or equivalent view from the pump), use a finger either side of the pipe to push the plastic face away from the boiler or away from the pump (towards the floor if positioned as advised earlier). The plastic face may need rocking during this process to manipulate any remaining wire over the last sub-mm of flange.
    • The joint should disconnect gracefully. If the joint does not disconnect, examine the centre hole of the plastic face again, checking where the wire is fouling the cone-flange. Reposition the three other pointed tools -previously left in place holding the wire apart- as necessary.
    • The 'O' ring each end of the plastic U-pipe will be easily accessible once the joint is apart. The inner diameter is approx 3mm. Outer diameter is approx 5mm ('O' ring is 1mm thick).
  18. Nespresso Inissia Disassembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Photo 1 and 2, note the tapered edges, these hold the wire clip in place. Reinstallation is simple, just push the on again.
    • This was as far as I was able to go. In my case the part shown on the right in photo 3 was leaking in between the metal and plastic. Sadly it couldn't be disassembled any further.
    Van you mark the spot where it was leaking?
    Marcel Veldhuizen - crwdns2934203:0crwdne2934203:0
    I noticed the water in between the plastic and metal part. Only later I was able to take the heater apart with force, the leak was inside, in de middle.
    The black part twists a bit to one side that way you can get it off. Needs quite some force, though!
    Léon Witteman - crwdns2934203:0crwdne2934203:0
    I have a leak at exactly the same spot. How do you fix this? I first thought it was the small o-ring, but I think it's where the heating pipe exits the heater…
    Steven Verbrugge -
    I had the same issue and by rotating the plastic part this can be removed from the boiler housing. Inside there is a small o-ring which in my case was worn. Now need to find replacement ring…
    Jeroen van Ruitenbeek - crwdns2934203:0crwdne2934203:0
    Hey Jeroen, I had the same leakage problem, and want to replace the o ring! did you manage to find out which o ring you need? I suspect it is this one, but not sure: https://www.partsnl.nl/ms-0019105-krups-...
    arno_holtrop -
    Hello, I did not test yet but I replaced the Oring by a nitrile P5 (4.8x1.9) Oring from a Oring kit I have. It fits well and need a little push that feel secured. I recommend nitrile Oring given the temperature and not rubber.
    [deleted] -
    Also got it off, using a screw driver on on side to rotate to the side where there is visibly space to move to. Inside tough, I couldn't find anything, also not that o - ring! Tomorrow I'll take another look I guess. I was wondering if any of you managed to fix the leakage problem in the end, as it seems I have the same problem (magimix m105)
    arno_holtrop - crwdns2934203:0crwdne2934203:0
    Hi, I had the same problem and arrived to the same step, but I couldn't remove the plastic part from the metal part. In fact I broke a bit the plastic part when forcing it.
    I would also like to know if anyone finally fixed it.
    Thanks!
    Javier Cebollada - crwdns2934203:0crwdne2934203:0
    Hi, I am close, just ordered a new o ring and will try to assemble tonight or tomorrow, I could show you a little video how to do it if you give me your email, I don't know how to post it here.
    arno_holtrop -
    I managed to separate the heater from black inner. Held in a vice, gentle tap to turn clockwise and it opens.
    There is a little o-ring inside the end of the black plastic. I pulled it out cleaned and reversed it back in.
    re-assembled it does not appear to leak, for now at least.
    Chris Miller - crwdns2934203:0crwdne2934203:0
    Do you happen to have pictures of the process? I have the same issue and can’t split the heater from the front plastic panel
    Avner Israel -
    Can you please show some photos of how to split the black plastic from the heater? Thank you very much in advance
    Boomer Liu -
    Anyone find the right o-ring to fix the leakage. I tried 2 different one, it all seems to thinner than the original one
    Richard Siao - crwdns2934203:0crwdne2934203:0
    Hi everyone. I seem to have the same exact leak as you all do but haven’t managed to separate the heater from the plastic part yet. I wasn’t planning to as I wanted to fully replace the part. And well, I didn’t think it would be so complicated to find that spare part. You can easily get it from european websites but it’s 230V… For some reason, I cannot find the heater element in 120V through North-American sellers… does anyone know where I could buy one? Thanks a lot :)
    Emilie Desrue - crwdns2934203:0crwdne2934203:0
    Hello Sir. May I ask except for the heater, is there any other part only work in 120V? I have a broken 120v machine ( CPU board broken ) and another broken 220V machine (black plastic part in the heater broken). I want to put the 220v CPU board and heater into the 120V machine. I am wondering if the pump is working on 120V? or it works on a fixed Voltage output by the CPU board? Thank you in advance.
    Boomer Liu -
    Yep mine has the same problem. Trying to find the right replacement o-ring now.
    Matt T - crwdns2934203:0crwdne2934203:0
    Hoi, Ik wil de Inissia aanpassen voor camping gebruik. Hiervoor zou ik een diode vb P2000M in lijn moeten zetten met de verwarmingsweerstand. Ik heb geprobeerd om de diode in de gele draad te zetten die naar het drukblok loopt (de gele draad die in stap 11 is te zien). Maar dat werkt niet. Het resultaat is een toestel waarvan de lampjes 3 keer kort flitsen, pauze en weer 3 keer kort flitsen. De diode zit dus mogelijk op de verkeerde plaats. Kunnen jullie me verder helpen?
    Frits Bonte - crwdns2934203:0crwdne2934203:0
    I used a large crowbar as a lever to open the brew unit's bayonet assembly. As mentioned elsewhere, the size of the o-ring (in the cavity of the large black plastic part into which the small black plastic sleeve and metal pipe slide) is 4.8x1.9 mm. In my case, replacing this o-ring did not stop the leakage. A lot of work with no favourable end result. The brew unit does not seem to be made for repair. Regarding the two metal springs and the tiny pipe in the middle of them (behind the cup holder), the following video is useful: https://www.youtube.com/watch?v=TY_B_Ytz...
    La parte in plastica nera, collegata alla caldaietta, può essere rimossa. È sufficiente tenere ferma la caldaietta e ruotare la parte in plastica in senso orario. Spesso la perdita segnalata anche nella guida è associata ad un danneggiamento della parte in plastica in corrispondenza dell’innesto con la caldaietta. In altri casi, più fortunati, è sufficiente sostituire l’o-ring che si trova in corrispondenza di questo innesto, per evitare la perdita. La parte in plastica difficilmente si trova come ricambio singolo, solitamente è associato alla caldaietta, tuttavia se disponete di un’altra macchinetta da cui recuperare parti di ricambio, è possibile mantenere la caldaietta e sostituire solo la parte in plastica.
    Andrea Golisano - crwdns2934203:0crwdne2934203:0
    Muchas gracias Andrea, copio la traducción:
    La pieza de plástico negra, que está unida al caldero, se puede retirar. Basta con mantener quieta la caldera y girar la pieza de plástico en el sentido de las agujas del reloj. A menudo, las fugas que también se indican en la guía están asociadas a daños en la pieza de plástico del acoplamiento con la caldera. En otros casos más afortunados, basta con sustituir la junta tórica de este acoplamiento para evitar la fuga. La pieza de plástico raramente se encuentra como pieza de recambio individual, suele estar asociada al caldero, sin embargo, si dispone de otra máquina de la que pueda recuperar piezas de recambio, puede conservar el caldero y sustituir sólo la pieza de plástico.
    Après plusieurs manipulations en tout genre j’en ai conclu ceci :
    Le joint est celui vendu pour la XN250 de référence MS 623318 qui est un joint torique
    Cela n’a pas arrêté la fuite et donc c’est le corps de chaudière qui est responsable quand celui-ci monte en pression de micro fissures laissent passer l’eau.
    À vide sans capsule il n’y a pas de fuite c’est uniquement quand on met la capsule donc plus de pression !!
    Donc changer le joint ne suffit pas dans la plupart des cas et on a que la solution de changer la chaudière
    THIERRY BRENAGET - crwdns2934203:0crwdne2934203:0
    Aussi j’ai eu l’expérience d’avoir la tête en plastique qui fuit alors qu’aucune fissure n’est visible à l’œil nu et je pense que c’est la tête qui est la cause des fuites et donc on ne peut l’acheter pour la remplacer cette pièce n’est pas vendue
  19. Nespresso Inissia Disassembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Assembly is the reverse of disassembly. The next steps are some points of note.
    • Photo 1: reverse of step 11: The easiest way to reassemble the side is to lay it flat and lower the inner body onto the side.
    • Photo 2: reverse of step 11: Make sure the black line goes over the white one.
    • Fit the rubber collar back over the pump.
    Also photo 2: make sure the spring is pushing against the plastic flange, and not going through it as pictured. The machine will be very noisy otherwise.
    Andrea A - crwdns2934203:0crwdne2934203:0
    Please clarify do you mean the tube should not be within the spring?
    anony Ab -
    I think he means that in my photo, on the right side of the spring it went through the cutout in the plastic housing. The tube does need to go through the spring, but the spring needs to be a bit more compressed to seat in the plastic rim. Imagine the spring in my photo to be compressed to about half its current length and it's still touching the left white plastic part.
    Léon Witteman -
  20. Nespresso Inissia Disassembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nespresso Inissia Disassembly: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Photo 1: Don't forget this cover.
    • Photo 2: reverse of step 10: make sure the clips line up with the slots.
    This machine seems to be identical to the Krupps model XN1001. Your instructions were very helpful with the reassembly.
    Repair Café Venlo-Zuid - crwdns2934203:0crwdne2934203:0
    Hey, my nespresso inissia’s cup holder fell off when I was emptying the used pods. I can’t seem to re-attach it. I didn’t find any broken or missing parts either. Please can you contact me on my email: sheza.umar@yahoo.com if you can help me out with it? Thank you!
    Sheza Umar - crwdns2934203:0crwdne2934203:0
    My clips don't secure the tube to the water heater, leading to leakage. How do you secure the clips? I ended up buying some new clips thinking it would make a difference but they are still very loose and don't hold the tube in
    william chou - crwdns2934203:0crwdne2934203:0
    Would you know the size of the o ring in the chamber?
    kristopher - crwdns2934203:0crwdne2934203:0
    Thank you, this description helped me a lot to repair my DeLongi Type EN 80 B (same). My problem was a o-ring in the pump (inner diameter 4,1 x 2). It was getting hard and the pump did not work any more. I replaced it with a diameter 3,5 x 2 and the machine make good coffee now again.
    Matthias - crwdns2934203:0crwdne2934203:0
    Traducido a Español el comentario de Matthias:
    Gracias, esta descripción me ayudó mucho a reparar mi DeLongi Tipo EN 80 B (igual). Mi problema era una junta tórica en la bomba (diámetro interior 4,1 x 2). Se estaba endureciendo y la bomba ya no funcionaba. La cambié por una de diámetro 3,5 x 2 y la máquina vuelve a hacer buen café.
    Me ha venido perfecto tu manual, la férrea me pierde Justo por la unión que comentas y he desmontado la pieza! Para sacarla es necesario girarla el sentido horario con fuerza pero con tiento, y ahí se aloja un sello que se deforma con el tiempo.
    Jero Calvo - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow these instructions in reverse order, please take note of steps 19 and 20.
crwdns2935229:085crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Léon Witteman
crwdns2935283:009/29/19crwdne2935283:0
2,375 crwdns2915208:0crwdne2915208:0
crwdns2947412:043crwdne2947412:0
I wanted to diagnose a leak so I took it apart to about step 10, set the water tank in place, plugged it in, and started a cycle. The heater got hot (the large metal assembly at the top) and when the pump came water gushed out of the joint with the tricky spring clip, the rear one that connects to the metal pipe leading into the heater.
I disassembled the clip (unplugged first and let it cool off) and found that the O-ring inside the joint was split. Now to find a replacement.
Darin Fitzpatrick - crwdns2934203:0crwdne2934203:0
Hi Leon, thanks for taking the time to make this guide.
I followed to step 11. Then I noticed the boiler had lots of white limescale streaks on it, indicating a leak. I think this is the part you diagnosed as leaking for you. I’ve decided to give up unfortunately.
Cheers John
John Moule - crwdns2934203:0crwdne2934203:0
There's another stage you can go! The plastic moulding the pod fits into can be removed from the boiler casting. You need to rotate the moulding about 15° clockwise on the boiler using a bit of leverage between the trunions and the moulding both sides. It's rather stiff but once turned it releases a sort of bayonet fitting retaining the moulding to the boiler.
Inside there's another ‘O' ring, that can be suspect for a leak, and a plastic sleeve behind it.
Steven Wilkes - crwdns2934203:0crwdne2934203:0
Thank you! Great addition.
Léon Witteman -
do you know the size of the o-ring?
Alex Diepeveen -
Alex, I haven't measured or taken pictures. The ring is approx 8 mm in diameter (from memory!). Don't know is this is of much use for you, though.
Good luck!
Léon Witteman -
the seal is 4.8x1.9mm
Will Stirling -
Well done Steven Wilkes
k.raymond -
This is a nice guide for a machine that I found to be a nightmare to work on - mainly due to the (all too common) practice of using snap-together plastic components, rather than screws. After the plastic has aged for a few years it inevitably becomes brittle and the clips often break during disassembly. My machine was a Krups Nissia XN100 model what was just on five years old. While there were some differences in the design, your guide was very useful - particularly so because your photos are clear and detailed. I found a leak at the “front” of the heater at the join to the black plastic moulding that forms part of the heater assembly. In an earlier comment, I saw that it’s possible to separate the plastic moulding from the heater so that the O-ring seal can be replaced. Despite applying quite a lot of force, I couldn’t get mine apart :-( I’ve since found that I can buy a new machine for less than three times the cost of a new heater assembly, so I decided to abandon the repair.
midahed - crwdns2934203:0crwdne2934203:0
Can someone tell me if there is a small circuit-board battery in there that one can remove/replace to reset the machine?
Andrew van der Merwe - crwdns2934203:0crwdne2934203:0
Thanks for this excellent guide. I am nearly there, a utube video suggests it is an o ring. Just need to get the second inner side off now and I should be there! I suspect I will need glue/gaffer tape to re-assemble, I heard a lot of clips breaking to get to this stage…..
Geoff Hayday - crwdns2934203:0crwdne2934203:0
Great helpful guide! My heater assembly was leaking. Ordered a new one on partmaster.co.uk which was half the price of one on a Dutch website. For certainty I also replaced the high pressure connector and o-rings.
I also had a leak between the metal and plastic part of the heater assembly. This was due to a worn o-ring. I could get the plastic part removed by rotating and applying a bit of force. I replaced the o-ring with a new MS-0071881 but still it was leaking. I assumed due to little pressure reamaining. I added a second o-ring on the other side of the small plastic pipe inside the boiler, this added just some extra pressure on the new sealing ring to make it seal.
Same issue here,, tried to add o ring as you did but leak is still here.
Have you durably solved this issue ?
I often repair Nespresso Coffee Machine and i never found how to solve the issue durably for customers...
Need each time to replace the whole part : boiler and plastic (which include the o ring)
More over i continue to think that there is a sort of glue between boiler and plastic on the new part... when i dismantle....inevitably there is no glue anymore...
Would like to repair the 3 or 4 boilers i have with me....all with the same issue...
Many thanks to you for your help
Kind Rgds
Gerald -
Est-ce que la fuite a disparu en ajoutant un 2ème joint
Thierry -
Buongiorno, la mia inissia si surriscalda troppo, dopo un solo caffè diventa bollente nella parte superiore, il caffè è ustionante, prima di berlo devono passare almeno 7/8 minuti. Cosa può essere?
gianmarcotrisciuzzi - crwdns2934203:0crwdne2934203:0
Brilliant guide thank you. One problem now I have disassembled it is I have 3springs which I do not know where they belong. The must have sprung off at various points and I couldnt tell where from. I can't see them referred to in the guide
Any ideas please?
anony Ab - crwdns2934203:0crwdne2934203:0
De casualidad no tendrán un tutorial como este pero para la Nespresso prodigio?
bob.pl - crwdns2934203:0crwdne2934203:0
For the Magimix the O-ring in the chamber has OD 32mm with a ringwidth of 3mm, so ID(32-6=)26 Look for FDA/ Foodgrade O-rings, with compound ‘70’. They are availlable online (in the Netherlands at least, prices range from eur 8,50 (10-pack) to eur 6,50 a piece.)
Type info: O-ring 32x3 - VMQ - MVQ - Silicone - 70 Shore A - Red - FDA - ORS9901
Repair Cafe Hilversum (NLD) - crwdns2934203:0crwdne2934203:0
Excelente informe de despiece, muchas gracias por compartirlo
Cesar Stefanuto - crwdns2934203:0crwdne2934203:0
can someone tell me why there isnt any water coming out of my machine, yes the pump does still turn onn but there isnt any water coming out.
Verpaele Delsin - crwdns2934203:0crwdne2934203:0
Es-ce que je peux démonter la pièce en plastique sur la résistance Krups Inissia sn1001
Make kilo - crwdns2934203:0crwdne2934203:0
hi ,
can i buy spare parts from ifixit ? for example the white plastic pin inside the thin spring at step 13
thanks
Ahmed Abbas - crwdns2934203:0crwdne2934203:0
Hola Ahmed Abbas Ifixit no dispone de piezas de repuesto de Nespresso, piezas tan concretas generalmente no se venden ni por otros distribuodores has de comprar un conjunto.
Hola Carlos López ,
muchas gracias
Ahmed Abbas -
Hi.
Issue with boiler o ring,, tried to add o ring as did above but leak is still here.
Kind Rgds
Gerald - il y a 3 jours
Gerald - crwdns2934203:0crwdne2934203:0
Did you solve this problem? I have the same problem and have tried several times with O rings of different sizes and can’t stop the leak inside the heater !
Jeremy Parker -
Hi Leon. Thank you for this guide. I need to replace the part on your "Step 2" (the part removed). Would you know it's name and part number? Thanks for any advice. Verona
@veronicathuesen Can you give us the part # in the exploded view, step 1, Pic 2?
VauWeh -
This page may help you.
VauWeh -
Thank you for the link to electrodo.de, what a great website. I managed to remove the part and the problem now seems to be somewhere else. Allow me to explain what happens when I do a coffee: very little water comes through the coffee pod, and lot of water comes from behind the pod sliding down from the part on the minute 0:49-0:52 on the video I sent earlier. I can see now that there is nothing wrong with that part in particular. Any further advice? Thank you very much for your time!
(I miss your video ;-))
The issue could be a clogged "pyramide"plate. This is a round plate with many little "pyramides", which peak little holes in the capsules, so the water/coffee can flow freely. We have a guide for a similar model, you can see the plate and how it is cleaned following from step 13. Think of replacing it with a new one, its cheap.
VauWeh -
VauWeh, THANK YOU!!!!!!!!!!!!!! Your words lead my husband to clean the inside of the machine with the dental water jet and lots of "debries" came out. As you said, it was clogged. Thank you VERY much for your advice. You saved us from buying a new machine!
@veronicathuesen Great! Repair is war on entropy!
VauWeh -
Felicitacioones y muchas gracias por tu comentario Veronica.
This machine is identical to the DeLonghi EN80b.
My machine was leaking, took it apart with this manual.
Martin Hilvers - crwdns2934203:0crwdne2934203:0
During disassembly an o-ring 8x2mm fall down. Can someone support me to find from where? I didn'd dismount the pump so cannot be o-ring inside connection to upper white tube
Alessandro Vignati - crwdns2934203:0crwdne2934203:0
Hi there, i repaired a delonghi en 80b with your advice on opening today.
My Maschine was leaking because IT was Standing in the cold for too Long.
The Problem we're Not the o Rings but the Connection underneath we're the White plastic parts are are clicked together one Side was broken so while running the pressure seperated them... I fixed IT with a thin wire which i slung around so IT was stable again...
Thank you very much for the Tutorial
Greets Dominik
Dominik Welle - crwdns2934203:0crwdne2934203:0
Please note that in the Type D40 version of this machine, it is not possible to remove the lever arm seats.
Fulton Fortner - crwdns2934203:0crwdne2934203:0
Thanks a lot for preparing this guide + the clear pictures. I would not have been able to fix my daughters Magimix without this guide. Another device saved from the scrapyard!
DannyK - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 98
crwdns2936753:07crwdne2936753:0 716
crwdns2936753:030crwdne2936753:0 3,433
crwdns2942667:0crwdne2942667:0 263,493
