If water drips out of the coffee maker, the brewing unit may be defective. The interaction of the capsule, brewing unit and "pyramid plate" is very sensitive, small changes in tolerance cause leaks at the capsule. The brewing unit may have an crack, or the "pyramid plate" that punctures the capsule may be heavily full with debris. Replacing the brewing unit often is the solution.
Remove all attachments: Water tank, capsule and cup drawer, drip tray.
crwdns2935267:0crwdne2935267:0iFixit Precision 4 mm Screwdriver Bit$2.99
The bottom is secured by oval head screws.
Remove five oval head screws securing the large bottom panel.
The bottom panel is just snapped into place. Insert a metal spudger into the slots and lift the panel out. It sits quite tightly and you might use some force to get it out.
Use a spudger to slide off the two silicon tubes.
Disconnect the two spade plugs on the blue and brown wires from the power switch. The two left ones remain.
Remove four oval head screws from the small bottom panel.
Remove the main device from the base. It´s still connected with some wires, but this doesn´t bother much.
The two colored side panels are only snapped into place. However, the latches sit very tight. You really need a lot of force. First lift the lower edge using a plastic opening tool.
Unfold each of the side panels upwards and remove them.
Insert a opening tool in the gap on the bottom of the coffee spout. Pry it off carefully.
Are there more steps?
Get the wires out of their holder.
The plastic cover over the brewing unit is secured by two clips on each side. Use a metal spudger to pry them off.
Lift the cover slightly, but don't remove it, it is still connected by some cables.
Open the lever and lift the cover out over the lever. Make sure that the cables are not strained too much.
Put the cover aside, but leave the cables connected.
Use a Torx T10 screwdriver to remove the four screws securing the brewing unit.
Use a metal spudger and insert it into the seam between the inner coffee spout and the brewing unit. Pry off the coffee spout.
Remove the inner coffee spout.
Der Kaffeeauslauf lässt sich im unteren Bereich nur lösen, wenn die Brüheinheit vorher gelöst und angehoben wird. Also wäre es sinnvoll Schritt 14 vor 13 zu machen.
Das ist genau richtig, was Christian H. geschrieben hat. Man muss dann nur die Brüheinheit festhalten, dass sie nicht runter fällt, wenn man den inneren Kaffeeauslauf löst und entfernt. Gerhard M. 10.7.2023
Danke für den Hinweis. Habs getauscht.
The brewing unit now remains only attached to the hot water hose. Use the metal spudger to pull out the metal clip at the end of the hose.
Pull out the end of the hot water hose.
Lift the brewing unit from the device.
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0VauWehcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:07crwdne2947412:0
Hallo schönen guten Tag ich habe Problem mit meine Gran Maestria Espressomaschine... habe einen neuen Brühkopf eingebaut wie komme ich an den Wasserschlauch in der Maschine..mfg
Hallo ich habe Problem mit meinen Nespresso-Maschine gran Maestria.. habe den Brühkopf neu ausgetauscht wie komme ich an den Wasserschlauch dran
Brilliant! A very helpful guide and essential to have the ifixit special tools. Two points - the inner coffee spout is easier to remove once the brewing unit has been unscrewed (Steps 13 + 14). Also, suggect the the inner coffee spout is cleaned before replacing as it can often be partially blocked which can lead to leaks.
It can often be difficult finding the correct brewing unit (my machine was a KRUPS) - obviously the manufacturers try to make it difficult for you!
Ich habe die Schritte 13 und 14 getauscht, vielen Dank für diesen Hinweis.
I have swapped steps 13 and 14, thank you very much for this tip.
Hi, great guide thanks. When I cleaned the brewing unit a small piece fell, and I don’t know where it belongs. A small black piece with a spring and a sort of cylindrical joint. Does anyone know where this goes?
@ericlesage , these parts belong in the water entry port of the brewing unit, i.e. where the water hose connects to.
To be more precise about these parts:
Referring to the round opening at the back of the brewing unit (third picture of Step 15)
-> Put the small spring on the black piece and insert them into that opening, with the "head" of the black piece oriented outwards.
-> Then insert the transparent joint into that opening and push it down into the opening as far as possible.
Note that the joint has two different sides:
One side has a cylindrical opening which the water hose will go into.
The other side has kind of spherical opening which will sit on / touch the head of the black piece.
