Nerf N-Strike Elite Retaliator Spring Replacement
crwdns2942287:0crwdne2942287:0A fatigued spring can be detrimental to your blaster’s performance. This guide shows how to disassemble the blaster to replace this component. There many small components such as screws and springs that will be removed in this procedure. Be sure to record their locations for easy reassembly.
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the stock attachment point by removing the two 8mm Phillips head screws.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
Itd be nice if we got a pic comparing the internals to an old yellow nerf recon (if you have one). I wonder how much changes between generations.
Removed every screw and gun does not separate. not showing the seperation of the gun makes this tutorial completely useless.
You have to remove the thing you use to ready it
It would be nice if you could color-code where to put the 16mm, 10mm and 8mm screws. That way, you don’t wind up damaging the screw post or stripping a screw by trying to insert a 10mm screw into a post meant for an 8mm one.
it's very helpful that the troubleshooting for slider won't move backwards goes to "Another two must be removed with the sliding mechanism in the back position." How, just how do you do that if it's jammed
please help if you can
definitely not angry at the troubleshooting page
While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
crwdns2935229:011crwdne2935229:0
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
can i use a nerf kronos spring
