Nerf Alpha Trooper CS-18 Firing Spring Replacement
crwdns2942287:0crwdne2942287:0If the primary firing spring becomes jammed or damaged, your Nerf rifle may have a decreased firing distance, or even worse may not be able to fire at all. This guide will explain how to replace the primary firing spring of the Nerf Alpha Trooper CS-18.
Note: This guide may also be used for the purpose of upgrading the primary firing spring of your Nerf Alpha Trooper CS-18.
crwdns2944105:0crwdne2944105:0
Look at the rear of the rifle. Remove the two 10 mm Phillips #0 screws that hold the black cap to the rear of the rifle.
Remove the black cap.
Point the barrel of the device to the left. Remove the two 8mm Philips #0 screws holding the device slide together.
Keep the barrel of the device pointing to the left. Remove the three 10 mm Philips #0 screws from the bottom of the device slide.
Once all screws are removed, separate the two halves of the device slide and put them aside.
Keeping the barrel of the device pointing to the left, remove the 14 10mm Phillips #0 screws from the body of the device.
With the device pointing in the same direction, remove the two 5 mm Phillips #0 screws from the body of the device.
With the device pointing in the same direction, remove the two 8 mm Phillips #0 screws from the body of the device.
While gripping the cartridge insert, pull the two halves of the device apart.
You should now be able to pull the primary firing spring from the rear of the rifle for replacement.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:02crwdne2947412:0
Im trying to look for a replacement spring but dont know the specs of the spring. length and force. any idea? or anyidea where i can find a replacement?
Did you find out? I need to know as well.
