This guide will show you how to replace a faulty laser.
Grab the rear bumper with both hands on either side.
Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
To remove the top, you must press in both of the clamps at the same time and push upwards.
Lift gently upon the top panel.
Unplug the clip located on the right side before completely removing.
Locate and unscrew the four 12 mm screws located in the black cap with the phillips #00 screwdriver.
Lift the black cap to reveal the laser.
Gently pull back on the gold laser to remove it from the socket.
Unplug the mini LCU clip by gently pulling up and remove the laser.
Where did you buy a new gold laser?
This is my question too!
Me, too; where to buy the laser…..
crwdns2947412:09crwdne2947412:0
lol. You don’t need to open it to replace the laser. The top is a clip on. Just pull it and remove 4 screws.
where do you buy the replacement laser?
I too would like to know where he got a replacement laser.
where do I buy a replacement laser?
bjurgensen79@gmail.com
Beverly Jurgensen
Where do I buy a replacement laser?
Beverly Jurgensen
I found some replacement lasers:
How many do you have to buy? Is it just one?
I replaced the laser and its still not working. Any other ideas?
In my case a spider had made its home in the lens opening in the drum which caused the unit to throw a 3000 error code. Removed the web with a pick and reassembled. That was the issue. Not kidding.
pull the free bottom corners out a bit to free the catches
wilfried - crwdns2934203:0crwdne2934203:0
