This guide will demonstrate how to remove and replace your Nabi 2's charging port. The charging port allows the charging cable to attach to the device, and over time the part may stop functioning correctly. There are many reasons to perform this repair, but the most common causes are the port becoming loose, and the device not charging. This repair involves the use of a soldering iron; be very careful not to touch the hot end of the iron while it is plugged in. It is recommended to document the order of the charging port wires before you detach them so that you can attach the new battery's wires in the correct order.
Remove the rubber bumper from the tablet.
With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using a spudger, slide the brown tab forward on each side of the connector
Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
If the screen is not working correctly, you will need to replace the entire display assembly
que aser cuando no le pasa carga a la bateria
Where can I go to get a new screen
Use the spudger to pop the battery out of place and set it aside.
Desolder the battery connection and remove the battery completely
Note the color order for future replacemement
Using the soldering iron, detach the speaker's wires from the circuit board.
Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
Once the screws have been removed, remove the speakers from the device.
Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
Remove the tape that is attaching the motherboard to the plastic casing
Remove the motherboard by lifting from the area indicated
Using a soldering iron, desolder the charging port from the motherboard
Remove the charging port completely
If the glue does not completely detach from the board, try to heat it until the charging port can be removed
crwdns2947412:07crwdne2947412:0
I think you would be better to just through it away and get something else.
Naw they are still a handy fairly tough tablet for the kids shame about badly designed dc port I managed to find ports for it on ebay.
send me a new nabi in the mail today
A lot of unneeded work there. The power port is surface mount and and can be replaced without removing the PCB or anything else, but the back.
Donnie
Do steps 1-3 above then 4 desolder power port and clean area then reverse order.
Donnie
Bought a new battery and still wont turn on. but, wont charge. now what.
Not to be a Ralph Repeater, but I agree with Donnie here, not sure why this article instructs you to take everything apart. That's just asking to get yourself into a major pickle, by tearing cables or losing small parts. Literally all you do is take off the rear, and it's right there, skip from the first set of photos to the very last photo. The author of this article is a real Johnny Overkill.
Also, can someone check on Deborah Cramer above, as I think she may be having a stroke. She has requested a replacement Nabi, from a unrelated repair site. I saw it in at least 3 different search results. What a goose!
