If your antenna for your Motorola V557 is experiencing poor connectivity or bad signal reception, then you may need to replace the antenna.
This guide demonstrates the simple steps necessary to complete this replacement.
By following the steps in this guide, you should experience improved reception and/or better connectivity. It is important to have a working antenna on a phone like this as they rely on the antenna to make phone calls, deliver messages, and mobile data.
Before you begin this repair, make sure your device is powered off and unplugged from the charger.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
To reassemble your device, follow these instructions in reverse order and flip directions. Take your e-waste to an R2 or e-Stewards certified recycler.
