Motorola Moto G7 Power Rear Camera Replacement
  1. Motorola Moto G7 Power Rear Camera Replacement, Weaken the adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener or a heat gun to the bottom edge of the screen for approximately two minutes to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G7 Power Rear Camera Replacement, Loosen the rear cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Loosen the rear cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Loosen the rear cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the rear cover, as close to the heated edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert an opening pick into the gap you created under the rear cover.
  3. Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the bottom of the gap to slice through the adhesive securing the rear cover to the midframe.
    • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this, you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  4. Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the gap on the same side of the phone as the SIM card tray to slice through the adhesive securing the rear cover to the midframe.
  5. Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the gap at the top of the phone to slice through the adhesive securing the rear cover to the midframe.
  6. Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly lift up the rear cover starting from the right side.
    • This will prevent damage to the fingerprint sensor connector under the left side of the rear cover.
    • If lifting the rear cover is difficult, slice through any remaining adhesive with an opening pick. Reapplying the iOpener can also help weaken the adhesive.
    • Use a finger to press down on the fingerprint sensor until it separates from the rear cover.
  7. Motorola Moto G7 Power Rear Camera Replacement, Remove the rear cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Remove the rear cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear cover, taking care not to damage the fingerprint sensor.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
  8. Motorola Moto G7 Power Rear Camera Replacement, Remove the fingerprint sensor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Remove the fingerprint sensor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger into the divot at the top of the fingerprint sensor connector cover.
    • Gently pry the cover open.
    • Remove the cover.
  9. Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry up on the fingerprint sensor connector to disconnect it.
  10. Motorola Moto G7 Power Rear Camera Replacement, Remove the motherboard cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the ten screws securing the motherboard cover to the midframe:
    • Nine 3.5 mm screws
    • One 3.0 mm screw
  11. Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under the motherboard cover.
    • Pry the motherboard cover upwards to lift it from the motherboard.
    • Remove the motherboard cover.
  12. Motorola Moto G7 Power Rear Camera Replacement, Disconnect the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Disconnect the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
  13. Motorola Moto G7 Power Rear Camera Replacement, Remove the rear camera: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Remove the rear camera: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G7 Power Rear Camera Replacement, Remove the rear camera: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up on the rear camera connector to disconnect it.
    • Remove the rear camera.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G7 Power Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Kim
crwdns2935283:002/16/21crwdne2935283:0
11.616 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2942667:0crwdne2942667:0 485
