Motorola Moto G7 Play Fingerprint Sensor Replacement
  1. Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
    How long do you have to use the heat gun before the glue loosens?
    Pamela DeMars - crwdns2934203:0crwdne2934203:0
    It's worked for me with about maybe 15-20 seconds of heating per side.
    Matthieu Bister - crwdns2934203:0crwdne2934203:0
    I could not get the pick started under the cover. Ruined several tips. I started with a hair dryer and switched to a heat gun. Be careful with a heat gun! 😬
    K Goatee - crwdns2934203:0crwdne2934203:0
  2. Motorola Moto G7 Play Fingerprint Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Fingerprint Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Fingerprint Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
    My g7 power had a removable connector at the phone side
  4. Motorola Moto G7 Play Fingerprint Sensor Replacement, Fingerprint Sensor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Fingerprint Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed
  6. Motorola Moto G7 Play Fingerprint Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G7 Play Fingerprint Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit opening tool, carefully disconnect the ribbon cable connecting the fingerprint scanner to the motherboard.
    • Remove the fingerprint scanner from the device.
Monserath Casillas
crwdns2935283:002/10/20crwdne2935283:0
1.188 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G4, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S7-G4, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S7G4
Do you need to replace the adhesive on the rear cover? Or is it reusable?
wtwolfe - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,819
