Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement
  1. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Heat the edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the right adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the right adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the right adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  4. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the bottom adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the bottom adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  5. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the left adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the left adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the left adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  6. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the top adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the top adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  7. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice around the camera bezel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  8. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  9. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Heat the camera bezel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  10. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Slice the adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  11. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the camera bezel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the camera bezel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the camera bezel: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  12. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Unfasten the motherboard cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  13. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Unclip the right edge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Unclip the right edge: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Unclip the right edge: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  14. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the motherboard cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the motherboard cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the right edge of the cover and pull it off the motherboard.
  15. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Unfasten the loudspeaker: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the six 4.1 mm-long screws from the loudspeaker.
  17. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Pry the loudspeaker assembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Pry the loudspeaker assembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger between the frame and the right edge of the loudspeaker.
    • Pry and release the right edge of the loudspeaker.
    • The loudspeaker is secured loosely to the frame by small clips.
  18. Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the loudspeaker assembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Stylus 5G (2022) Loudspeaker Replacement, Remove the loudspeaker assembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the loudspeaker by its right edge and remove it.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
92,073 crwdns2915208:0crwdne2915208:0
crwdns2935297:0459crwdne2935297:0
Hi Clay. I really like your posts and articles! Great stuff! I am replacing the speaker in my Moto G Stylus 5G 2022 Model xt2215-4 . Do you absolutely have to remove the Mother board and disconnect the battery when doing this? Even if you turn the phone off or run down the battery? The speaker as know is at the bottom of the phone below the battery and is not technically hooked up to the motherboard, so why go to all the hastle of removing it and disconnecting the battery? It looks like an easy repair just to open her up and remove the speaker compartment and pop an new one in. Why take out the motherboard? Thanks, Steve
Steve Paul Jaws - crwdns2934203:0crwdne2934203:0
Hey Steve! We recommend this to protect the phone as a whole when replacing a critical part such as a speaker. You're right that it does come out very easily and would be a very quick repair without first disconnecting the battery. We just don't advocate for this because of the risk of short-circuiting something on the board, or subjecting a live board to a replacement part with a lot of built-up static. If, for some reason, you can't remove the motherboard cover to access the battery connector, you can give it a shot without doing so. Just keep in mind the risks and use lots of safety practices surrounding ESD. Electrostatic Discharge
Clay Eickemeyer -
crwdns2942667:0crwdne2942667:0 1,055
